Motor knocking, barely idles, wont accept gas. Toast?
Old 12-16-2011, 06:11 AM
Yotamonstah's Avatar
My truck has done this randomly lately, usually after a car wash, or a puddle. I'll be driving for a bit fine, then all of a sudden it'll start cutting out, then soon after bog out and die, then impossible to start. The other day it did it, and i had to get towed him, and now it runs like garbage, motor knocking, motor has always leaked oil, but it may have leaked too much. I'll go to start it up now,and when i hit the gas pedal, it'll instantly die. Fuel pump, filter, and carb(carb was bought used but functioning) not more than 1month ago. Fuel lines replaced. Is my 450,000 mile 22r toast?
Old 12-16-2011, 06:17 AM
waskillywabbit's Avatar
Make/model in your sig would help with future questions.
I think it might be due a rebuild.
:wabbit2:
Old 12-16-2011, 06:19 AM
Uploaded with ImageShack.us
sorry lol that might help.1987 xtracab 4x4 5speed 22r
Old 12-16-2011, 06:21 AM
Sensei's Avatar
Cuts out after a wash or puddle... could be your distributor is getting moisture inside causing driveability issues. Pull the cap and check it out, may be able to keep the truck on the road for a few more miles...
While your at it check your whole ignition system. Couldn't hurt.
Old 12-16-2011, 08:48 PM
binky_rutledge's Avatar
Exactly what Sensei said, sounds like a distro problem, run through the ignition system, whens the last time you did a cap, rotor, plugs, wires? Maybe just give it a little tuning love...
Old 12-17-2011, 10:48 AM
would it not start for days though and idle like crap?
Old 12-17-2011, 10:50 AM
from one puddle?
Old 12-17-2011, 11:04 AM
XtraSlow_XtraCab's Avatar
It CAN if the moisture is not able to escape the distributor. My only discrepancy with this solution is, it will IMMEDIATELY run like a turd after a wash... you'd be lucky if it even started in the first place.
BUT, its an easy enough solution. Simulate the problem (wash your motor) and verify it still runs bad. Remove dizzy cap, wipe it out with a paper towel... maybe even blow dry it, and throw it back on. If it runs better, voila. If not, I'd check the ignition coil.
The ignition coil is one component that a lot of people overlook and, when failing, it reacts inconsistently and can only be inspected with a multimeter and not with guesstimation.
Old 12-17-2011, 11:20 AM
hmm, i will have to look into that. And for the 2nd part of your response, how many volts should I be reading from the ignition coil? Thanks!
Old 12-17-2011, 11:22 AM
Mmm... off hand I can't say for sure. Never had to myself... but if you look in my signature (the area below that lists my vehicles) there is a link to downlaodable, FREE factory service manuals. I would imagine it will list a testing procedure along with what kind of values you'll be looking for.
Old 12-20-2011, 08:33 PM
I went to start it after a good 5 days of sitting in the dry, and it'll turn on and idle, but the second I hit that gas pedal, it immediatly dies
Old 12-20-2011, 09:01 PM
muddy chevota's Avatar
i agree check distributor cap DONT BUY NEW take a blow dryer and dry the cab and distributor out passing a propane torch over the inside of the cap QUICKLY works as well, if it still dosnt work try changing your fuel filter its cheap or just take it off and blow through it into a clear container that's dry see if water in fuel that is a cheap free start to find problem
Old 12-21-2011, 09:27 PM
i just really think its a fuel problem, because it'll start idle for less than a min then die. If i start it up, and hit the gas, even a little love tap, instantly it'll die. i just replaced the fuel filter less then 2months ago??
Old 12-21-2011, 09:28 PM
and the carb worked fine and was replaced around the same time thats y im scratchin my head
Old 12-22-2011, 05:27 PM
How about the fuel pump?
Old 12-22-2011, 08:32 PM
its brand new, not even a month old
Old 12-22-2011, 09:39 PM
4wd4fun's Avatar
igniter?
Old 12-23-2011, 03:35 AM
And you don't think it could be faulty? It sounds like a mixed bag (ignition and fuel), the engine isn't getting fuel (press on the gas) and is misfiring (when moisture is present). I would check out that fuel pump even though it's new. Fuel filter shouldn't really be able to be faulty but if you've got a vacuum checker you could probably check that out too, also check for a kink in the actual fuel lines?
(thoughts of a noob)
Old 12-25-2011, 03:01 PM
figured it out. i had a gas cap of an entirely dif. vehicle, and it was sealed and not vented. ...
Quick Reply: Motor knocking, barely idles, wont accept gas. Toast?
