I want more MPG.
1 Post
I would switch to synthetic Oil even if I knew there would be a leak (as long as it's minor). I would say if I lost 2 quarts of oil between oil changes (say every 3500 miles), that would be acceptable enough for me to use synthetic oil compared to say if I was losing hardly anything with dino oil). The gas mileage improvement from Synthetic might pay for the quarts you go through, and the fact your truck is running synthetic which helps it run cooler (which promotes less warpage of critical parts like your head gasket), improves gas mileage slightly, improves power very mildly, and it overall runs like it's new without being gummed up, is enough reason for me to switch even if I was losing that much. Now if I was losing more oil than 2 quarts per oil change then it's time for a ring job or a short block rebuild. If you're losing that much oil per oil change, then how much fuel is also getting by into your crankcase as well? You could be destroying your oil's (synthetic or otherwise) ability to do it's job by having fuel mixed with it.
Switching all my drive train (front/rear diff, tranny, x-fer case) over to synthetic is on my next to-do list when the time is up. That will help mileage, power, and promote durability as well. I'm switching all my drive train over to Amsoil fluids - gonna keep the oil with Mobil 1 since I've always used it.
Originally Posted by oly884
To be honest, the best thing you can do to get better mileage is just go slower.
I take a different route to work now-a-days where i don't go above 60 mph and i'm getting 20-22 mpg with the V-6. When i'd take the interstate at 80 mph i'd get 16-17 mpg. Nothing was different about my driving except the speed.
But about the gas mileage question. Everyones suggestions are great. But another suggestion is driving habbits. I'm sure you already knew that but thought I'd throw it in anyhow. I feel your pain on the gas mileage thing, espcially cause my last vehicle got at least 25 mpg. But thats part of owning a truck/suv
I get 33+ highway. 36 lbs in tires with x cab and camper plus 400 lbs in back. 5 speed turbo 62 mph. 48 on engine but I have only a 4 cyl engine. but this truck flys.
#25
wow your guys are making great mileage im pushing 13.5 (all my driving is around town) and i baby this thing i have 32's on it and the isr mod but i still only make 13.5 mpg last year i had a new cap, rotor plugs and wires put in and i know my airfilter is clean. anymore suggestions?
#26
Originally Posted by YotaND
What should I use to clean and lube the AFM? I’m not to sure where to lube but I’m sure once I get it out I can figure it out. Also, why does my AFM sound like a Geiger counter? I know it is not the reed valve I'm hearing or any other part of the EGR system. I'm not sure if the sound originates from the AFM but that is where I can hear it. It is audible when the engine is running and very loud when I unclamp and open up the air box. I pulled the vacuum line from the left valve cover to the air hose and listened. I could not hear the noise there but it is hard to hear anything over the sound of suction.
Will too much oil affect my mpg? When I drove it off the lot the day I bought it the oil was over serviced. There is an oil leak that drips a few drops a min after it has been running. I’m not sure if it is caused by the overfilling or if the overfilling was to compensate for the leak.
<==E[/////////////////]F=======S========
This is about how high it is. The S is what my dipstick shows for oil level. What do you think?
#27
Originally Posted by noodle
I don't know much about 2nd gens but what about Cleaning the MAF sensor?
When I lubed mine, I just wiped the interior of the VAFM body down with a soft cloth and then used a very small amount of SPL 100 Lube on the hinge of the door. You can't really 'see' the hinge itself, but you can see where the door rotates on the body. A small spritz of lube in the right place and you're done. Don't let the lube get up into the electronics area on the top of the VAFM body.
If you're sure its the VAFM clicking, it could be stuck. The door in the VAFM is spring-loaded. I suppose it's possible that the return spring broke, but I've never heard of one doing that.
The over-fill was likely to compensate for the drip. An over-filled crankcase 'can' have a small negative effect on MPG, but it's more likely to cause premature engine wear. If the oil is too full, the counterweights and rod journals splash into it as the crankshaft turns. All this splashing when the engine revs causes the oil to foam. Oil that has turned to foam won't get sucked up by the oil pump. You can see where this is going. Just drain it down to the FULL mark and keep vigilant on leakage. When it gets down to the LOW mark, fill it back up.
Mike in AR
#28
my mileage
well i dont know about all of yall but i am getting about 12.7 with alot of it being highway i am going to try a few things like the manual hubs in the front and maybe something to the air filter i started running mid grade and a new fuel filter to get where i am now before i was at about 11.3 so i have gained almost a mile and a half so if there are any cheap improvements for a 3.0 4runner auto plz pm me
also when i start mine i smell gas expecialy if i start it and pop the hood to look under it is that normal or could i have a leak?? i have looked but i dont see one
#29
When I was having trouble with my O2 sensor I thought I could also smell gas when I started it. If your O2 sensor is bad it will run rich and kill your MPG. I wasn't sure if it was my imagination or not but I never noticed it after I fixed the sensor.
#30
#31
#32
I have changed the plugs, wires,and rotor cap. I noticed a big difference at first. I have a 188k on a 94 4x4 4 runner. Then I changed my fuel filter, all was well. Then a week later my wife had my car for about 5 days and noticed it was running slow. Checked the oil was low, added oil, started running better. Now a week later with full oil, it has no pickup and getting 14 mpg. Right after the tuneup it was about 17mpg. I don't know how to check or adjust the timing, could this be causing a lack of acceleration and poor gas mileage? Or is it just that I have 188k miles on it and its old?
Really would like to get some acceleration, any ideas on how?
