Help with wire harness clips?
Old 06-24-2010, 05:43 PM
Rob2thec's Avatar
Hey party people,
So just about done with my full rebuild.
The Motor harness is a mess, all the clips are trashed, broken or damaged in some sort of fashion. When I mean clips I mean all the little connectors that attach to the wiring harness to the motor; Injectors, sensors, ect.
Does anyone know if you can buy new replacement clips for the motor harness?
Or do you have to go digging at the junk yard and hope to find new clips?
1987 Toyota 4-runner 22RE, EFI, 4x4, 5 speed.
If you have good connectors let me know I will buy!
Old 06-24-2010, 08:02 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Have you called a Toyota dealership? I've had the fortune that they had connectors sitting in their parts bin in the shop that've been removed for whatever reason from customers vehicle. Got one for a TPS and temp switch that way. For a '92 3vze, no less. They don't normally have stuff like that.
Otherwise, I'd try contacting (private message) DeathCougar here on the YT forums. He's a SuperDuperMod and works for Nix99 used Toyota parts. If nothing there, try the YT marketplace. I've had good luck there. Or, try junk yards. But, I never have luck with junk yards around here. Yotas and/or their parts are scarce.
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
TDonkey
07-26-2015 10:14 AM
toofly1999
07-25-2015 07:09 PM
80Truck
07-24-2015 03:12 PM
msane99
07-17-2015 10:13 AM
Quick Reply: Help with wire harness clips?
