!!!HELP!!! truck stopped running (broke down)
Old 01-09-2013, 06:13 AM
bensyota's Avatar
just finished pulling engine. no machine work, just all gaskets and seal, valve adjustment. put it all back together and it ran fine. timed it, it was at 12 deg. i left it there. had it running for a while yesterday on and off while adjusting idle, bleeding ps, and filling coolant. all went well. last time i had it running yesterday it died itself. it was late, i didnt think anytthing of it, so i stopped for the night. well i went to take it to get the exhuast finished from dt headers back. went down the street a couple hundred yards and all the sudden it seemed like it was chugging for gas. it died, and wont start back up.. help, its sitting in fron of strangers house down the street a couple blocks. im gonna get it towed home tonight. or if you guys come up with something easy to check ill drive my other yota down to give it hell.
thank you thank you thank you, please help
Old 01-09-2013, 06:17 AM
waskillywabbit's Avatar
So what do the codes say is wrong?
:wabbit2:
Old 01-09-2013, 06:23 AM
bensyota's Avatar
well i have to o2 sensor code im sure becasue i dont even have it installed yet. so i didnt check the codes. that wouldnt make this situation occur???? that woudl be the smart thing i guess. i havnt done this in forever. can you reference me to a page real fast. i should pull the positive wire off the battery to reset it first, right? then check??
Old 01-09-2013, 07:15 AM
bensyota's Avatar
well, i just came back. i jumped the te1 and e1 terminals after turning the ign to on. the check engine light stays solid. i dunno whats going on. am i missing anything?? was also able to start it again and it died after about a minute
Old 01-11-2013, 12:19 PM
Sturmcrow's Avatar
I guess the obvious question would be, what led you to rebuild the engine to begin with? Was it running fine before the rebuild?
Have you checked the fuel filter and verified proper fuel pressure at the engine?
Old 01-11-2013, 01:32 PM
bensyota's Avatar
Ended up being a vacuum line I didn't plug. Thanks u guys . At shop getting 2.5" exhaust pit on with high flow cat. Post pics of everything when I get it back
Badger62811
06-26-2015 09:26 PM
ibayne
06-26-2015 06:30 AM
torgeir
06-25-2015 05:26 AM
WI Girl
06-25-2015 03:45 AM
mytruck
25
07-15-2002 04:28 AM
Quick Reply: !!!HELP!!! truck stopped running (broke down)
