Help with ticking from my 90 4runner
Old 12-25-2005, 07:25 PM
Stal's Avatar
i have been trying to figure out what is ticking from my 90 4Runner. I thought it was the lifters so I tore the thing apart and reshimmed all the valves, None of them were to far out of spec, after I put it back together it still ticks. The ticking noise if much louder when accelerating. Now I am thinking it might be an exhaust leak. I removed the exhaust manifolds and used some high temp sealant on the gaskets but that didn't help. I can hear the ticking coming from the engine compartment, and also from the exhaust pipe itself. If I get under the truck it sounds like there is a ticking coming from the cat. I have felt around as much as possible with my hand but can't feel any leaks. I would really appreciate any help you guys can offer, I'm stummped.
Thanks
Old 12-25-2005, 07:32 PM
suprathepeg's Avatar
What engine do you have? Toyota has notoriously loud injectors. Use a stethascope and see if you can rule them out.
Old 12-25-2005, 08:18 PM
Stal's Avatar
I used a stethascope to listen to the injectors and that wasn't it. It is the 3.0
Old 12-25-2005, 08:21 PM
Babypig's Avatar
Could be the fuel regulator, Injectors, wrist pins, depends on what area of the engine bay its coming from.
Old 12-25-2005, 08:24 PM
Toy4x4's Avatar
interesting i have the same sort of problem...after rebuilding i had a ticking so i reshimed but that didn't stop it. I thought I just reshimed wrong but the ticking is still there...so does anyone have a solution..I have also ruled out my injectors
Old 12-26-2005, 12:08 PM
87TurboYota's Avatar
Sounds like it could be the valves sticking.
Old 12-26-2005, 02:14 PM
90runnner's Avatar
worst case is a spun bearing allowing enough free play in the connecting rod allowing the piston to make contact with the cylinder head... yeah i had to deal with that. pull the oil pan and check your crank. its possible to fix with a crank kit if your heads arent too damaged as mine were. good luck, hopefully this isnt the problem, i ended up putting a whole new motor in my 4runner.
-andy
Flying91
45
04-11-2024 04:39 PM
BeMiceElf
10-10-2015 09:40 PM
cars-guy
07-11-2015 07:51 PM
smiley52
07-11-2015 05:16 AM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: Help with ticking from my 90 4runner
