Engine Questions R22?
Old 12-08-2016, 06:28 AM
tpafire5's Avatar
I finally got a battery and was able to start up my new to me 1st gen. It had a hiccup and died a couple times when i hit the gas after starting and immediately dying. Also there is a squeal after it warmed up a little. Any thoughts would be great.
http://vid164.photobucket.com/albums...psjo39kx4a.mp4
http://vid164.photobucket.com/albums...pspkvjnoip.mp4
Old 12-08-2016, 08:38 AM
Rusted Rooster's Avatar
Noise
hello. Sounds like an pulley bearing? Hard to tell from the video, the AC,power steering, I waterpump question?. If you have a automotive stethoscope. Or a cut off broom handle place it against your ear and the Area you think the noise is being generated from, other than that it sounds good!
Carry on! Tim.
Old 12-08-2016, 08:42 AM
Noises
And I hear a pretty significant Exhaust leak. Check donut gasket manifold to exhaust pipe. there's two of them they usually go bad.
Old 12-08-2016, 01:05 PM
tpafire5's Avatar
How do i know if the turbo is working?
Old 12-08-2016, 03:35 PM
Turbo.
Oh man! Did not even catch the turbo! That could be where your noises coming from?
Old 12-08-2016, 03:58 PM
tpafire5's Avatar
It doesn't sound like it, noise is in front
Old 12-08-2016, 11:21 PM
wyoming9's Avatar
Red face
First it is not a 22R it is a 22RTEC
Has this ever run since you bought it ??
Sounds like you have fuel delivery issues have you jumped FP to B+ on the check connector plug it should be on the left inner fender (I might be wrong without looking)
In any case in 86 it is a green and white/black wire.
Might be the AFM switch
Circuit opening relay
wire harness problems chewed wires
Solve one issue at a time or you will just frustrate yourself.
Old 12-09-2016, 01:25 PM
tpafire5's Avatar
Once I get it running it idles smooth and sounds good, if I step on the pedal to fast it sounds like it wants to choke out.
Old 12-11-2016, 06:48 AM
toyospearo's Avatar
pull the belts and run it for a spell. Thet will tell you if there is a bearing on one of the pulleys
I would rip that AC out of there if it's not working. At the very least disconnect the belt.
Sounds like an intake leak or AMF issue.
Check for codes
