Driveshaft removal
Old 04-17-2007, 07:23 PM
Mister Willie's Avatar
Driveshaft removal
So my U-joint noise came back recently. I'm certain it's a u-joint cause I turned off my 4runner and pushed it backwards in neutral and I could hear it squeak and creak.
Anyways, I work two jobs and since I don't have a lot of time to work on my vehicle..
Would you guys suggest removing the driveshaft for the time being (I'm talkin just til sunday) so that the Ujoint doesn't seize while it's connected and break more things? I could drive it in 4hi safely without the rear connected right?
Old 04-17-2007, 08:16 PM
MMA_Alex's Avatar
You can run it without the driveshaft if you want, however if you're gunna pull the u-joint in order to remove the shaft you might as well just replace them and fix the problem in the first place.
Old 04-17-2007, 08:24 PM
yeah you're right..
Old 04-18-2007, 05:51 AM
tc
tc's Avatar
Ummm ... why would you go to all the trouble of removing the ujoint to pull the DS - just unbolt the flange. 4 - 14mm wrench size bolts on each end.
And yes, it's fine to remove the driveshaft and drive around in FWD. The truck drives a little funny like that though.
Old 04-18-2007, 02:28 PM
JEBSR5's Avatar
I did that for about a week with no problem.
4x4-runner
04-18-2017 09:08 PM
mreagen
09-08-2015 03:46 PM
94yotaky
08-19-2015 11:15 PM
trailgoat
08-13-2015 05:54 PM
Tonetrk
08-06-2015 10:06 AM
Quick Reply: Driveshaft removal
