Change AC belt - Pulley Bolt broke - HELP
Old 08-21-2010, 11:36 AM
SpazedOne's Avatar
Question Change AC belt - Pulley Bolt broke - HELP
Good afternoon -
I am changing my AC, P/S & Alt belts - everything was going well untill the bolt to loose the Pulley for the AC belt snapped off (Behind the pulley)
Any idea what I can do now to get that long bolt out - It still has an inch of bolt on either side...
Old 08-21-2010, 11:57 AM
loke's Avatar
If you can grip it with vise grips, just unscrew it. If not, you can drill it and use an ez-out. Drill a small hole down the center of the bolt. The ez out is reverse threaded so when you screw it into the hole, it'll tighten counter clockwise. As it gets tight, it'll begin to unscrew the broken bolt.
Old 08-21-2010, 12:02 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
The bolt that holds the pulley on, or the one behind the pulley for the adjuster?
This happens all the time when ppl don't realize the the bolt that holds the pulley on also locks it so it can't move.
You HAVE TO loosen the pulley bolt 1st, then loosen it by the adjuster.
Yeah, but if it broke the bolt, it'll turn out with an easy out?
Old 08-21-2010, 12:45 PM
SpazedOne's Avatar
It was the adjuster bolt behind the pulley...It snapped off right at the bracket. The front bolt on the pulley was removed at the time as well -
Old 08-21-2010, 12:55 PM
Boy salt brings the suck, don't it?
Can you just hammer the part the bearing rode on, through the slot?
the1998sr5
15
07-14-2020 08:35 PM
oldirtydirt
02-23-2020 09:30 AM
jasonty
41
12-23-2018 01:00 PM
Amer
3.4 Swaps
19
06-05-2017 10:43 AM
dinks07
07-15-2015 05:34 PM
Quick Reply: Change AC belt - Pulley Bolt broke - HELP
