Carbon fiber hood with scoop for 2nd gen
#41
Originally Posted by rocket
Heres the scoop im probably using once i get some body work done and have the Runner painted.
#43
It is also probally worth noting that the 3rd. and 4th. gens.' scoops are somewhat w-i-d-e-r than the one pictured.
Bigger is always better, no matter what others may say.
#44
Originally Posted by 94x4
I'm not trying to "flame" you or anything and encourage you to not be "hesitant" about offering advice to other's about whatever 'misconceptions that they may have, just do so with a bit less prejudice would probally be a good judgement call.
#45
Originally Posted by 4RocRunner92
4. A hood is pretty heavy. If I got a carbon fiber one, which I would get for weight reduction, I would get one with a scoop (because I think it would look cool. Yes this is my opinion and im entitled to it like stated before in the thread.)
I'm glad a lot of information about how an engine is cooled was revealed in this. Yes TRunner I am ignorant to a lot of things about how an engine works. So what though? Thats why I ask this stuff like I said before. So I an get proper maintenance without disrupting the function of something else under the hood. (Like what happened with my air induction.) I mean no harm by anything I say. Everyone is being honest so I might as well be too. The fact that reading something and not verbally hearing it can lead to a lot of misconceptions of how to take the remark or comment. I greatly appreciate both of your opinions and your support 94x4
I hope you guys can throw me some more information in later problems I may have or questions I might need. Yes, there is a gawdly amount on knowledge about Toyota's on this site. I'm glad I found it.
#50
Originally Posted by Cebby
3rd and 4th Gen 4Runners both were available with and without scoops. Not sure if any of them are functional though.
I can tell you this, if I had a functional scoop on my rig right now, it would be completely pointless thanks to my bug shield.
#52
Reducing under hood temp is always a good thing contrary to some comments here.
-Most electrical components live longer in a cooler environment.
-The intake air could potentially be cooler since the scoop would have a chimney effect on evaculating hot air.
-Yes it's a watercoolered engine. Ironically, the thing that keeps the radiator cool is a FAN! A FAN moves air. Moving cooler air across the radiator will increase the cooling efficiency and the cooling system will not have to work as hard.
#54
No sarcasm or anything intended Churnd, but why on earth did you cut the entire bottom of your air box out??
#55
Check on the "3 years with zero problems", but surely you realize that there's a reason why all manufacturers plumb the air intakes to the outside of the engine compartment, i.e., cooler, fresh air?
#56
But also less... so it's like a trade-off. Most of the time you're getting more air that's cooler too since you're moving. The only time it hurts is when you sitting there idling in stop and go traffic. No different than the $200 FIPK kit K&N sells.
#57
O'kay, but I'd still try to plumb the bottom of your air filter box to the outsuide somehow just to get it away from sucking in the heated engine compartment air.
Also, for what it's worth, all I did was the ISR mod with the straight intake tube.
#58
I wanted to, but couldn't find an acceptable place to route any kinda plumbing. It would have had to come from the front, and that wouldn't have worked unless I cut through the wheelwell fender. That would have been too succeptable to damage, so I scratched the idea. I wanted as much air as possible, and I didn't think I'd be able to route the size plumbing I wanted without having to do serious fab work.
#59
How about ducting it to the lower valance under the bumper?
There is something like a grill structure down there that you could easily mount a funnel behind as the intake.
#60
Originally Posted by Travs97
your money your truck. if you do it post it them show the damn world that jason is different. a litte nc love
theres lots of mods people do that really dont make sense and some others think theyre stupid. let everyone do what they want to their rig. cuz in the end, whos paying for it? if you dont like it, dont do it to your tuck. enough said. put the lid on this can of worms, and go get you a hood with a scoop that you like, and ill help you put it on bro.
north cacalaky up on yotatech ya heard.
