Bolt sizes
Old 06-23-2013, 12:19 PM
Cwt622's Avatar
Bolt sizes
Hello everyone, I'm replacing the transmission coolant lines on my 1990 Toyota pickup 3VZE 3.0L V6. I need to know what size the nut/bolt is for the part number 32921C. If I knew the size I could replace it with alternative things instead of paying through the roof for it at the Toyota dealer. Thanks!
Old 06-24-2013, 12:34 AM
wyoming9's Avatar
Red face
Be nice to know just what you are talking about ??
Just what does that number refer to it is not a Toyota Part #
I must say Toyota is quite reasonable on their hardware prices.
If these bolts are holding something on They will most likely be M8x1.25 smaller would be M6x1.00 as for length you will just have to guess.:jessica::jessica:
Old 06-24-2013, 07:55 AM
MudHippy's Avatar
PNC 32921C has no nut/bolt. It's a tube union fitting. Most likely threaded JIS-PF(Japanese Industrial Standard Parallel Pipe Threads), and/or JIS-PT(Japanese Industrial Standard Taper Pipe Threads). JIS-PF threads are functionally interchangeable with BSPP(British Standard Pipe (Parallel) Threads), and JIS-PT are interchangeable with BSPT(British Standard Taper Pipe Threads, External). But good luck finding either.
Old 06-24-2013, 08:26 AM
snobdds's Avatar
Just get it through the dealer...more yes, but less hassle finding a compatible one and you know it will fit.
kgcwb44
01-29-2023 10:02 AM
justdifferentials
Just Differentials
08-30-2015 08:42 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
Gravel Maker
RuffStuff
08-06-2015 04:27 PM
Gravel Maker
RuffStuff
07-27-2015 06:53 PM
Quick Reply: Bolt sizes
