Best shocks for 95 SR5 4x4 to correct rear sag
Air shocks would help with sag some, depending on the air pressure you put in them (requires airing up about once or twice a month).
A new spring pack would be a great way to do it, or adding more leafs to what you have might be enough too.
ubolts can be found at napa or any parts store. bring an old one in so they can measure it for you.
or for about the same price get a ubolt flip kit, but then you have to do something different with your shocks.
the only problem i see with adding a add a leaf in your situations is that you springs in general are completely shot. they are sitting on the stock over load already. what an add-a-leaf does is add: 1. it's thickness to the spring pack, 2. it puts a little more arc on the upper springs. this is fine when the stock springs are actually arced and supporting the weight of the vehicle, but in your case your stock over load is supporting the weight of the not the actual springs. Personally I think you would be better off buying new springs because you add a leaf is going wear out very quickly supporting the entire back end of the truck as the normal leaves are not actually doing their job. I think you would be much more satisfied. even going out and finding a set of auto bone-yard springs might be better than those.
Shocks, air shocks in addition to new leaves if you do a lot of hauling would be good. if you have money left a good option for shocks would be bilstein. I have them in the front of my 4runner and really like them. Wish i had gotten them for the back too as the DT shocks are too soft for hauling and twisty highway driving.
#25
Im not into off-roading, unless you count drivin through my pasture as off-roading. To level my truck and gain some overload capacity I used Firestone air bags that I bought at Auto-Zone. Really easy to install and takes very little air pressure to level things out. Each bag has its own fill nozzle so you can level it right to left. I do pull a Kobota L3400 tractor with attachments from time to time and these bags work great for that. I dont remember what I gave for them, they have been on there for 3 or 4 years, but it was around 225. I think.....Regards...Rick
#26
#27
Been reading about the Zuk coil mod...pretty intrigued. Seems like a good solution without having to mess with the leaf springs, buying new ones, new u-bolts, etc. Can anyone tell me where to order the springs and the brackets and stuff?
#32
Been reading a lot about the coil mod on Zuk's website...I feel like I'm pretty much sold on the idea. Seems like 60 bucks plus 10 bucks shipping will pretty much solve my problem. Apparenly you don't even need brackets or welding, just use the lower rubber bumper stop thing and cut the upper one off the frame partially - so cool!
I'm just trying to determine if I want the 12'' or 14'' inch coils, hmm - anyone have advice with that?
#33
#34
Thanks, Alex, I definitely will - do you have any advice regarding 12'' vs. 14'' coils? I really just want to restore ride height, not add lift, but I'm nervous that if I get 12'' they might not be quite enough...
#35
I wouldn't be the one to ask. I have a 4runner where i have put better springs, but i have never done the zuk mod to a leaf sprung truck.
#36
After reading a bunch of write-ups, I decided to go ahead and get the 14'' 100lbs springs. I figure if it ends up too high, I could always cut a little bit off of the springs.
#37
new nitrogen charged shocks will lift the back a small amount, maybe an inch if you get the heavy duty ones. the expanding effect on a nitro shock will wear out as the shock gets older, letting the rear settle and actually hold the rear of the truck down.
a really good fix to saggy leafs is an add a leaf. a common misconception about them is they will make your ride stiffer. it will make your spring rate higher, but not as high as the overload your riding on all the time.
#38
Yeah Matt, that makes sense. I was thinking I might put on new shocks while I'm doing the spring mod. Seeing as the springs should help soften the ride up (actually the ride isn't too bad right now anyway), is there any reason to use higher end shocks like Billsteins, or would it not be much of a difference to just use OEM stuff.
#39
what he said. farther more, to explain your problem and help you make a decision, your stock spring pack has lost spring rate due to old age and constants use. a add-a-leaf will add rate back to your pack and help your stock worn out pack. an absolutely perfect fix in your scenario.
#40
