Best parts to swap from 4runner into pickup?
Old 03-12-2011, 06:59 PM
bigredscowboy's Avatar
I have first dibs on a 93 4runner. done lots of searching and it seems as though everyone loves to pull sr5 seats and gauge clusters from 4runners for their pickups, but what else?
I was planning on grabbing the rear-view mirror light assembly, but didn't see much else that was transferrable.
Old 03-12-2011, 08:01 PM
aviator's Avatar
Actually pretty much everything electric is transferable except the drivers side window controls if it's a 4dr. you can grab the steering column surround and with the body control module (attached to the crossmember above the hood release) get the ignition light if you don't already have it... the glove box light maybe transferable too. you will have to swap the seat tracks from the truck onto the sr5 sests to give yuo enough seat travel if you have an xtra cab.
Old 03-12-2011, 08:02 PM
tpaine14's Avatar
i snagged sun visors with mirrors :p not to mention lower gears, the dash clock, i think v6 rigs had a better brake set up than 22re pick ups? bigger booster or something idk. then just all the front end parts in case you ruin anything on yours plus just to have as spares... thats what i did anyway
Old 03-13-2011, 08:49 AM
is the cruise control transferable?
Old 03-13-2011, 09:32 AM
Flash319's Avatar
I like the SR5 square style mirrors better.
Old 03-13-2011, 12:44 PM
ProjectMcFly's Avatar
Ooh, I didn't know that the 4Runner had an ignition light. I definitely miss not having that in my truck.
Is the glovebox light plug and play? I have the complete base model truck, which at first I figured wouldn't be such a bad thing, but now I'm realizing all those little things I'm missing out on.
Once I get back on my feet, I'm so going to junkyard until my feet fall off.
Old 03-13-2011, 02:09 PM
aviator's Avatar
With a great deal of difficulty yes... the cruise on these yotas is a vacuum operated unit so you need to grab the steering wheel and column guts, the brain box, the vacuum motor, the throttle body and the wiring
some runners have the light others don't it (and the glove box light) were part of the 'convienence light group' or something like that...
the glove box light is not quite plug and play put pretty close you just nned to tap into a live 12v source and a ground... the attachment pts. are more or less there you may have to glue the light socket into the hole that is there is all... the switch will pop into it's hole.
Old 03-13-2011, 02:13 PM
toyota4x4907's Avatar
Its not exclusively v6 4runners. Later model 22re 2nd gens (like my '95) has the larger brake booster, larger diameter master cylinder and 4 piston calipers.
Old 03-13-2011, 03:07 PM
iamsuperbleeder's Avatar
not plug and play, but yeah snag the 12v outlet and ash tray light, glove box light, and dash speaker boxes for sure
Old 03-13-2011, 03:14 PM
angrydogtattoo's Avatar
power antenna
Old 03-13-2011, 09:15 PM
is the brain transferrable from a 3.0 to a 22re (or any of those things for that matter)?
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
vasinvictor
01-20-2016 12:39 PM
Outsane
06-24-2015 05:52 PM
streetuner15
06-18-2015 10:59 PM
Juan Manzione
06-10-2002 04:12 AM
Quick Reply: Best parts to swap from 4runner into pickup?
