AFM to MAF
My 4 cylinder 88 Ford Thunderbird Turbo Coupe & 86 Mustang SVO both had VAFM's on them. They had no problem producing 300 HP with some engine work & a few mods. Maybe having a turbocharged engine is better with a VAFM? Maybe those cars would have performed even better with a MAF? Not for sure. Just thought I would toss in the fact that some engines can produce plenty of power with a VAFM.
There isn't a kit that I know of. The one I made was just a proof of concept prototype. Kitting it was deemed too expensive to do in small quantities.
Did you ever post this to guage interest- or is this site not techy enough. How about advertising for interest on the Supra, Cresida, pirate, etc sites as well? I think your min order was 100? I bet you could market this to LCE and perhaps engblder as well.
I am serious about wanting this. Just a note- this was for 22re apps right?
#25
I'd have to make around 100 units to make it worth while. The cost would still be around $140 for each converter. You would still need to buy the MAF sensor from a wrecking yard and a cone filter to fit it. The entire conversion would likely cost close to $250 in all. I don't know that it's really worth it for the money.
#26
Well the issue here is that either your customer goes with the Supra afm or your maf...subtract the cost of the (and the bs of getting one) Supra afm $100 right there, if it works it's a 1982 part after all. Those GM maf's are a dime a dozen and I can do better on price. So is the mod worth $150 difference. I think yes, options are limited for getting power in this app and freeing up space. LCE charges $300 for a bored out TB- how does the performance of that mod compare with this? Most everything I see for these apps are little bandaids- this I see as a step forward. Another thing to consider- you see $250 as too much, let the market tell you- but not on this forum
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
