94 Toyota Pickup NO FUEL NO FIRE
Ok ive got a 94 toyota pickup V6 3.0 M/T. The other day i went to start the truck and nothing except the starter turning over. The fuel pump is not coming on and also no fire on the plugs. I have changed the coil and ignitor, distributor cap and rotor. I have read a few posts on this issue and have tried a few things but still nothing, I switched the EFI relay with a known running truck and still nothing also have power on efi fuse on both sides. When i pull the EFI relay out i have constant power to one post and i think with the switch on i am supposed to have it on two but it doesnt change with the ignition switch. I also do not have power to B+ in diagnostic box so i jumped the constant power from the EFI relay to fp and the pump will run when i tried to start the truck it started and ran for 2 seconds and died and then the truck would not even turn over went and checked the starter relay and it was burnt out so i dont know if i did something or it just went out any help would be appreciated Thanks
Aleeex_u
06-05-2016 06:52 PM
WTB[International]: 93 P/u fuel door lock, roll bar, hitch, chrome rear bumper
Gamble_STi
06-27-2015 07:54 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
