91 timing tensioner
91 3.0 3vze timing tensioner
91 3.0 3vze
Tensioner with the bolt in the bearing and spring to hold the tension. After setting the timing marks and installing the spring what does the bolt in the bearing torque to? Seems odd to leave that bolt loose and tightening it holds the tensioner from moving unless its loosened back up.
