86 Toyota 22r pickup won't start
I need some help guys I bought an 86 Toyota pickup with 22r motor and I can't seem to get it running I have spark gas and air and now I am lost anybody willing to help me out??
Sorry didnt even think about that my mind is a million miles an hours right now. I do not know the trucks history when I bought it the woman said it had been sitting for 10 years untouched, the man told me 2 years with little detail except the truck had no power no matter what no lights noises turn nothing so it was parked and left. So, here's my move, I established that the motor wasn't locked turning it by wrench,it has oil and no obvious contaminants in oil, gas obviously bad so I tested with new gas after letting as much as I could out from lines and carb the distributor rotates so timing chain is at least intact and connected I have spark on all 4 cylinders, I got nothing from ether either it made no difference the plugs were in the wrong order I believe the firing order to be 1432 so that's what I put it in, and now I think timing may be off because the rotor does not point at cylinder 1 at tdc but I'm also unsure and heated some more input before I tear the timing cover off (edit- I haven't had the chance to do a compression test yet but with finger over the hole method I did have some compression)
