3vze swap with 3.4L... is it worth it for what happened
Old 08-02-2008, 08:21 PM
4RrunnerJ's Avatar
well i took my head off and found that there was a nut that somehow got into the pistons and totally jacked everything up... so now im wondering what would be worth doing,,, buying a new car.. which i dont have the money for right now.. or putting in a 3.4L from the 96 and up.. can anybody give me some suggestions...thanks
Last edited by rocket; 11-15-2008 at 02:10 AM. Reason: Please read the rules! Specifically #3
Old 08-02-2008, 08:26 PM
abecedarian's Avatar
In my opinion the total cost of one option would be comparable to the other.
Old 08-02-2008, 08:32 PM
kcrunner's Avatar
Depends on the mileage on your engine; if it's relatively low, just rebuild it. I would say if you can't afford a newer car, you probably wouldn't be able to afford the 3.4 swap, unless you know someone that's got a 3.4 for cheap. I just priced a low mileage 3.4 yesterday from a salvage yard in Texas for $1300, not including shipping. Yikes.
Old 08-02-2008, 08:36 PM
Elton's Avatar
i did the 3.4L swap well it came with the truck its alot better than that 3.slow i had
Old 08-02-2008, 10:02 PM
jason191918's Avatar
Originally Posted by 4RrunnerJ
well i took my head off and found that there was a nut that somehow got into the pistons and totally f***ed everything up... so now im wondering what would be worth doing,,, buying a new car.. which i dont have the money for right now.. or putting in a 3.4L from the 96 and up.. can anybody give me some suggestions...thanks
correction: 95.5 and up
Old 08-02-2008, 10:08 PM
toyotanick's Avatar
ok thats just bein a smartass
Old 08-02-2008, 10:36 PM
iamsuperbleeder's Avatar
haha
How bad did it mess things up? Dinged up piston? Scrapped up the cylinder walls? Bent a valve? If it doesn't look like a nome with a jack-hammer was playing around in the cylinder, I'd say just rebuild her; if it's the 3.0, it may be overdue for the HG job anyway. If just the valves or piston are messed up, those are replaceable. But if the cylinder walls are pretty scared up beyond what looks being able to bore or hone out, I would just see about getting a junk yard 3.0 to drop in, seeing how money is tight like you say... I've been in that situation, so I know how that is...
But if you come across the extra cash, I would say yes, opt for the 3.4 swap. It's a little more work, but you'll be happy with it in the end.
Old 08-02-2008, 10:40 PM
76ANTHONY's Avatar
well it cost me 500 bucks to rebuild my 3.0 and it runs great, but i really want a 1uzfe, so im savin up the cash to do that swap.. 3.0's are cheap to rebuild....
Old 08-02-2008, 10:44 PM
JsEngine&repair's Avatar
Im in kinda the same delema. Im going to rebuild my 3.0 despite all of the problems they are known for. If I find a 1998 like I want with the bigger engine, its going to be easier to sell the 91 with the original engine and not some swapped in engine(unless you find a offroader with appreciation for it) even though the 3.4 is a good engine, my 3.slow has 330,000 miles on her and still runs(on 5 cylinders its still better than the 22re) without any prior maintenance....why would I put anything else back in?
Old 08-03-2008, 07:15 PM
4RrunnerJ's Avatar
Originally Posted by iamsuperbleeder
haha
The cylinder head is pretty jacked up and so is the piston, but it doesnt look like the walls are bad which is good, thank god, but i was doing some looking up on rebuilds, and a remanufactured head and it seems pretty reasonable, im just tired of having no power and getting 9 miles a gallon, but maybe if i do the whole rebuild then it should be almost good to new, the truck has 140k miles on it but the motor was just rebuilt and has about 10k on it, then the head gasket blew and thats where everything went wrong.... go figure
Old 11-12-2008, 06:26 PM
NYChopshop's Avatar
second that!
ditto, minus the rebuild. My 3.slow is chugging along at 150k, and im saving for the 1UZFE swap asap. displacement: 3.4 vs 4.0? 4.0l lexus wins! 6 cyl or 8? do I really have to answer myself? Look into it. get a band-aid engine or do the repair until the economy picks up a bit Otherwise, it'll be like a grand for the engine (750 on ebay) and a few grand more for the imported components. Seems the aussies will stick damn near anything in their precious hiluxs.
Old 11-12-2008, 06:34 PM
NYChopshop's Avatar
BTW, the best thing I've done for my 3.slow so far is help it breathe better. The damn OEM intake is so stupid its sad. Unfortunately, they never considered the possibility of a larger diameter throttle body sensor, so only a smart intake system will really do anything for us. Not like its been night and day, but I got a couple miles per gallon and real world horsepower (not to mention the best part of the sound of my truck!) out of my S&B cold air intake. I got mine from ebay but from an authorized retailer. I got mine shipped a few parts short, but they were really good about sending the stuff quickly. The only real remedy for our infamous 3.slow is a swap, however.
Old 11-13-2008, 08:36 PM
WestCoastMoose's Avatar
Has anybody considered this....?
http://www.doaracingengines.com/page7/page7.html
They have taken all the things wrong with this engine and beefed everything up. And a few choices to go along with it.
Simple swap , stock HP or higher,and all the problems fixed. Same price as all the other swaps, no hassle, and can do any add ons you like. Win Win win
Old 11-13-2008, 11:28 PM
space-junk's Avatar
do a search on here and you will find many a yotatecher that is unhappy with the service, or will flat out REFUSE to have anything to do with DOA...
Old 11-13-2008, 11:42 PM
scuba's Avatar
Thats like calling the european fecal matter and standards and having them come polish your turd
Old 11-15-2008, 09:04 AM
904_runner's Avatar
The 3.4 is indeed a good engine from what i have experienced with it. We have a 99' 3.4 auto and it is pretty quick. Needless to say, when my 3.0 goes out, im gonna 3.4 swap it. That is my plan
Old 11-15-2008, 09:37 AM
YoterUp's Avatar
look at my signature i got my whole rebuild on there mechanic dropped a washer in mine. the rebuild wasn't bad if you follow directions and can remember little details its easy. i got all my prices on there 2. the swap is expensive if your going to swap anything screw the 3.4 and go 4.3 sry to say it its a bigger more powerful CHEAPER motor!
Old 11-15-2008, 09:43 AM
1stgen4gunner's Avatar
well i took my head off and found that there was a nut.
HAHAHAHHAHHA, if you read it slowly its really funny.
Old 11-15-2008, 05:46 PM
RobD's Avatar
Yeah, but then you have part Toyota, part Chevrolet.
It ends up coming out a Toylet.
Old 11-15-2008, 05:55 PM
76ANTHONY's Avatar
Quick Reply: 3vze swap with 3.4L... is it worth it for what happened
