22re lcengineering throttle body spacer
Old 03-22-2008, 01:46 AM
Matt16's Avatar
Originally Posted by dcg9381
The 07+ Tundra puts down 381 hp and slightly over 400 ft/lbs. That ain't bad as it's emission legal... It gets 14-18 miles per hour based on realistic ratings.
so does my bicycle
Old 03-22-2008, 04:45 PM
joshuapc's Avatar
and my legs...
Old 03-22-2008, 04:47 PM
joshuapc's Avatar
i just wana squeeze power without decreasing my gas mileage. the po rebuilt the motor, headers, and an exhaust. i made an intake. i was thinking of a cam but worried that would limit my gas mileage. any comments?
Old 03-22-2008, 08:44 PM
Targetnut's Avatar
Search for "mods" advice for the best bang for your buck on these things.. I do agree with above, however, than unless you really dump some money into them (like crazy money) that the best you can hope for is 10-20% improvement.
It does require extensive mods to see a substantial improvement, however you can get by without spending the whole bank if you can do it yourself. I think I've actually spent about $2300 for all my engine modifications. but I have several hundred hours tied up in it. I figure if I paid for all I've done, I'd have spent well in excess of $6000
Generally increasing power means increasing your engines ability to burn fuel. which means more fuel consumption. As long as you don't go overboard, and can keep your foot out of it most of the time, you can increase power output and get similar fuel mileage, but usually if more power is available then it gets used, leading to worse gas mileage.
A slight upgrade in the camshaft, along with a slight increase in compression ratio can give a power increase with out hurting fuel economy too much.
smthwsn357
05-01-2024 07:28 AM
06-01-2021 01:51 PM
montanatruck
02-26-2017 07:07 AM
09-04-2015 09:27 AM
raiderhawks00
07-08-2015 06:23 PM
Quick Reply: 22re lcengineering throttle body spacer
