1987 Pickup - 22r - Stalls when pulling away
My '87 pickup has had an intermittent stalling out problem that seems to be getting worse. When it happens, it's usually soon after I started it and pulled away from a parked position. Then it is really difficult to get it started again. Sometimes it just won't start off the bat but usually it's the first scenario. I usually can get it to start if I spray carb cleaner in the carb but that trick is getting less and less effective.
Any input would be much appreciated.
Thanks!
Thanks!
