floor
Mine is holding up really good and the smell was almost like new car smell
One or two edges have peeled because I didn't sand aggressive enough.
A patch under my clutch has dissolved due to leaking clutch which was unnoticed until after the floor was done
One gallon will be enough for a regular cab with two coats with enough left to do a tailgate (I did a test on my tailgate which had very little sanding and just a coat of xylene prior to -> it's held up really well considering I drag steel trash cans across it)
I'd recommend the durabak if you want to use a colored bedliner.
my friend coated the inside of his cab with duplicolor bedliner. Its holding up OK only had it in for around 3 mos so time will tell. We just sanded it like heck and then wiped it down with some acetone.
BigHoss_27
09-21-2015 07:44 PM
