bleeding power steering?
So I just replaced a leaking steering box on my 85 4Runner. Got it all back together, flushed and bled the system, and I now have little if no power steering. I flushed and bled it by running the reservoir return hose into a container while the engine was running and I turned the wheel complete lock to lock a number of times while keeping the res full. I have put about 100 miles on it and the reservoir is still full but no ps. I'm guessing there may be air in the lines still? Using Napa steering fluid.
Any ideas?
Any ideas?
Bleed the system with it raised up like your avatar
http://forum.ih8mud.com/79-95-toyota...ing-issue.html
I will fix your title from brake woes to something about power steering
definitely put it up on jack stands than turn lock to lock 20 times without engine on and than do it about 30 times with engine on when you reconnect the return line make sure you turn lock to lock to get all air out of the system
delmert
09-30-2015 04:34 PM
