93 4runner 3.0 Dies.
Old 08-20-2012, 08:44 AM
iselloil's Avatar
93 4runner with a 3.0 17,000 miles will run great when first warmed up.Then I can go around a corner,hit a bump and then the truck has no get up and go,or acceleration.Hit another bump and it will run great,then next bump, it will go to crap.All of the grounds are intact.I know I'm looking into pulling the harness down.Anyone had the same issue?
All new TPS,AFM, tune up,Temp sensor,speed sensor.
Old 08-20-2012, 10:52 AM
BMcEL's Avatar
There is a thread about this around here somewhere. The engine harness rubs through where it crosses up front.
You're in the 84-85 section BTW...
Old 08-20-2012, 10:57 AM
cheech2112's Avatar
it rubs through right under the battery on the passengers side ive had this problem before also could be the EFI relay ive also had that do it as well
Old 08-20-2012, 11:11 AM
iselloil's Avatar
I will check it.I've not looked there.I see I posted it in the wrong spot.
Old 08-20-2012, 11:17 AM
cheech2112's Avatar
let me know what you find when you remove the battery
Old 08-20-2012, 11:35 AM
iselloil's Avatar
It will be this weekend, I'll let you know.
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
tobylab
01-18-2016 07:06 PM
MTLroadierunner
07-15-2015 12:58 PM
tobylab
07-12-2015 12:53 PM
Roger Borba II
07-09-2015 05:05 PM
Quick Reply: 93 4runner 3.0 Dies.
