Want to Lift my 82
Want to Lift my 82
I am new to this forum, and I am wanting to put a suspension lift on my 82 long bed. How big a lift can i put on the truck without having to lengthen the drive shafts or any of that junk? Is it 3" or 4"? Wanting to run 34x9.50x15 TSL swampers!
i dont think they would fit without lifting i know they wouldnt fit on my 89 but i would go for 4 in just to be safe and it would be beter and it would look beter =]
just be careful around the turns if u dont put new axels or wheel spacers
an 89 is nothing like a first gen, with a 4" i could run 39s....
34" Nittos no lift
35s with a 2" body
33x12.5s on 10 wides stock
34" Nittos no lift
35s with a 2" body
I guess i really don't have to lift it to run them, but i assumed that in order to have flex i would need to lift it at least 3". When you had the 34's on did you rub any at all on or off road?
But RUF or a kit with a new hanger would fix this by moving the front forward 2"s, But also would lift it....sooo
Get friendly with a BFH to to the pinchweld and you should be fine
Run a 2" or 3" lift and you should have no problem with tire contact, and no driveshaft issues. Please don't put on a crappy lift. Search around this forum for a million opinions on lifts - most of them, though, come to the same conclusion: crappy lifts are not worth the time it takes to install them, much less the money to buy them.
I plan to use it for both. I want to be able to drive it on the road everyday if i choose, and want to 4-wheel as well, but i want it to perform like it should off road.
justdifferentials
09-05-2015 06:52 PM
joeynational
09-05-2015 01:54 PM
