Brake Master Cylinder
i seen a few engine bays on this site and noticed alot of new looking brake master cylinder. where are you guys buying these from? i see them on ebay for a pretty decent price. like to know where you guys are getting them. thanks
I got one off of Ebay for about $50, no quality issues / worked fine. The other I found in a junkyard for $5, but it was clean, looked new and I made sure the pedal didn't fade before I yanked it.
corax: thanks, might be my best option price wise
i spend 50 bucks for piece of mind on mine. and it came witha nice clean resivoir and black paint on the master....
Besides the FJ80 upgrade, a 3rd gen Hilux (1989-95) is a great choice as well if you want to keep everything Hilux (this is what I've got in my 1981).
Just remember that once you start mix-and-matching master cylinders, your brake pedal may feel heavier/harder to press. In this case, you'll also need to increase the size of your brake booster to compensate for the larger master cylinder, however this is not required.
I see you've got two trucks listed in your sig. Take note that the first gen cab positions the steering shaft closer to the brake booster, so you will only be able to fit a 2nd gen booster in there. But on your 1988 2nd gen truck, you will be able to fit a 3rd gen booster as well (it will need to modified just barely for clearance). But again, you do not have to upgrade your booster, your brake pedal will just be harder to press is all.
BigMike
BigMike
I did a 3gen master and DD booster on my 1st gen trekker ..
I used a 2WD shaft ...
works great .. you can see more here http://toyotatrekker.proboards.com/i...ead=33&page=18
reply 261
and yes .. it's used
reply 261
if u work for toyota u should be able to get the parts guys to order one for you cheaper then u getting it and have it sent to your place... but thats if u work at the dealership i use to do it all the time when i work as a parts guy..
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
