AISAN CARB ISSUES: Should I fix, rebuild, or replace w/ new Weber carb???
I have a dilemma I need help with, please... I have an 83 22R with Aisan carb that won't start unless I spray stuff in the carburetor - and then BOOM it starts instantly. It will idle on it's own while warming up but it bogs down if I gun it. It has only 60,000 original miles (because it's a motorhome that wouldn't get started for several years at a time).
I want to get the starting issue fixed and then desmog it.
The way I see it is that I have three choices...
1) Fix the starting and bogging down issues but I don't know what is causing them.
2) Rebuild the Aisan carb, but why would a carburetor with only 60,000 miles on it even need to be rebuilt?
3) Replace the original Aisan carb with a new Weber.
What would YOU recommend?
Thanks!
P.S. I'm not a mechanic but I'm good with tools and can follow directions.
Thanks!
I'm not sure if the choke is functioning or not, but maybe these three photos will help.
1 PHOTO (left): This was cold and before I tried to start it.
2 PHOTO (center): After trying to start it with NO starter fluid. (It would not start.)
3 PHOTO (right): Started using starter fluid and after letting it run for a few minutes. (I couldn't keep it running without keeping my foot on the gas.)
If the carb is dead dry from laying a long time between uses; long cranking times are to be expected.
Does it run well with good power once it is warmed up??
Looks like the choke is closing some. Might need to adjusted for even greater cold choke. Do you pump the accelerator vigorously before attempting to crank??
I'd probably go with the Weber. My 81 is desmoged, with the stock carb. It runs descent for the short distance I drive it everyday. At some point I will switch to a Weber.
Be sure to get the real Weber. I've always heard there are cheap knock-offs out there.
Sitting for years will gum up a carb. Sitting is actually terrible for vehicles. Expect an old truck with low mileage to act like an old truck with high mileage. When sitting, seals and bearing don't get lubricated, gas goes stale and gums things.
I had a 78 Chinook and put a Weber with a manual choke on it. I loved it. There seem to only be a few select people with a "touch" for carbs. Everyone else has nothing but trouble rebuilding them. I haven't even had good luck with professionally rebuilt carbs.
When you pump the gas pedal, as in starting a cold engine, you should see fuel squirting out of this port, it is circled in red.
That's the manual accelerator pump.
If it doesn't, then you either have a clog circuit or a damaged diaphragm.
The condition of the carburetor in your pictures looks to be in poor condition. The insides looks too dirty, or corroded.
I personally think cars that sit for long periods of time will suffer much more degradation than one that is regularly driven. I think the carburetor and the rest of the vehicle would be in better condition mechanically if it had twice the mileage.
It is up to you if you want to rebuild your original carburetor or get a new one. I bet either way, the engine will benefit.
Depends on use..
I ha e an 87 4x4 that is stock with all smog control in working order. I was told by professional you performance guys that you can not desmog with the Asian carb. My truck gets an average of 22 mpg no matter how I drive it. I am still considering a swap to a Webber and a desmogging kit only because I would like a little more power. Not sure how much more I will get though.
Desmogging
I didn't say you couldn't, I said it is not advisable since the Asian is a backfeed carb and needs the smog stuff to function properly. Sure, a lot of "kids" have removed some smog stuff and truck runs ok. I have an 87 with Asian and all smog equipment and the drivability is there and I get 22 to 28 mpg depending on how much trailing I do. Take off anything you want,,, not necessary...
DO NOT USE A WEBER. They are not great. A properly rebuilt Aisin Carb is way more reliable. I work at a landcruiser specialty shop and every weber that has ever come in gets "tuned" a couple times before its ultimately replaced by a rebuilt aisin. I will add that doing a desmog will bring the engine to life even more (at least on the land cruisers)
Weber worked great for me. I agree that a good aisin carb is better, but they're so old now...and so many people do crappy rebuilds. A really good rebuild is one thing. But unfortunately carb experts are getting harder and harder to come by.
Webers are brand new and easy to tune, though they definitely take consistent fine-tuning to stay in the "zone". I will admit that I only had about 20,000 miles on mine when I sold the truck, so I can't say how well they do long term.
