Morimoto Bi-Xenon Projects, headrest and master cylinder
All items are off a 1997 4runner Limited.
First is an extra front headrest that I have. No rips or tears. Great condition for what it is. $10 +shipping
Second is an OEM master cylinder. I replaced it due to a soft pedal, but was probably due to old fluid. Doesn't leak and could use a soft exterior cleaning. Perfect for a rebuild. $10 + shipping
*****PROJECTORS SOLD
And lastly is a projector retrofit kit using Morimoto Projectors, bulbs and wiring harness.
Bi-xenon Morimoto Mini Stage III Kit (D2S) - Complete Retrofit Kits from The Retrofit Source Inc
Mini D2S Stage III:
*3Five watt ballasts
*Color - 5K
*H4 bulb relay
*E46-R Ext shrouds
Complete harness + 3Five ballasts
Harness
Projectors + Shrouds
Scratch - Just above center. The spickles you see is dust.
Scratch - 12 o'clock. The spickles you see is dust.
Bulb - Broken tab
Bulb - Broken tab
These will be sold without the buckets. After removing them, I came to the conclusion that they should be in the garbage, not on a vehicle.
The bulbs have one broken tab on each bulb. Doesnt hurt performance, but should be noted.
The lenses on the projectors have 1 scratch on each lens. Again, doesnt hurt performance, but should be noted.
$165+ shipping located in South Texas.
Interested in trades.
* I could go for some shocks and struts for a 3rd gen. Brand and shocks dependant.
Mini D2S Stage III:
*Color - 5K
*H4 bulb relay
*E46-R Ext shrouds
Harness
Bulb - Broken tab
Bulb - Broken tab
My 4runner has been totaled a total of 3 times and because of this, my drivers side and passenger side is a bit off. Not thinking too much of it, I did the retrofit. However, when I tried to aim the cut-offs, they would never line up. I also used Ebay non-oem housings (pure trash) which also left me sour about the whole retrofit, so I removed everything.
