Strut/coilover R&R: Spring Compressors - your thoughts
So I have two vehicles that are due for new struts/coilovers, my 4Runner and our 94 Accord. Instead of spending a bunch of money to have a shop get the springs on the struts/coilovers so I can install the entire thing, I am thinking about adding another tool to my collection: A spring compressor.
I have heard various things about a tool such as this. I hear they are dangerous if used incorrectly (understandable), and that some are better than others.
What are your experiences with spring compressors? Are they easy to use? I have found a couple external ones that go for around $60. That seems worth it to me. I also have air tools and a ball joint puller, which I hear helps a lot when installing new suspension components.
I want it done right, so I want to do it myself. Any thoughts on this tool/task?
Yeah, I think they do. However, I wouldn't mind having one of my own for $60. I just want to know how dangerous they really are, and the experiences other folks have had with them.
Here is one on Amazon: Spring Compressor
Originally Posted by Localmotion
I used them on my coil springs (OME 881s) and the broke off and hit me 4 inches about the "treasure" We did use an impact gun which might have A LOT to do with it. LOL Id say invest in FilthyRichs wallmount compressor. That thing is incredibly easy to use and safe!
Wallmount compressor sounds like the way to go. I've seen several of those cheap compressors break/strip threads/bend/etc.
I've heard good things about Branick, and FilthyRich is selling one...
https://www.yotatech.com/forums/show...ght=compressor
EDIT: OOPS, he beat me to it
both .. basically he charged me 1/2 an hour of labor
edit: I just wanted to be clear, that I removed/reinstalled the shock/spring myself. All they did was remount the new shock onto the spring.
Yeah, that's what I thought. Sounds like that is the most economical/safest route to take for me too; even if it ends up being $90 for 2 vehicles (2 on the 4Runner, and 4 on the Accord).
When we did the fronts on mine, Steve and I were able to rent some garage time and they provided the spring compressor. It was sort of scary watching that thing flex wondering if it would explode.
When we did Bob's, we took them to a garage that had a wall mounted compressor. I think they charged $60 but it was probably well spent - much quicker and much safer.
Y'all are making this just a tad too hard....
Spring compressors bring the suck.... I stripped on pulling coils off of my old Tundra. I use a hydraulic press instead. Check out Bill Morgan's writeup and coil over adapter: http://www.4x4wire.com/toyota/projects/blackbean/ome/
The Accord is our DD, so I am going to get lowering "sport" springs, which will only drop it .25", yet make the R&R much faster.
The Branick is the best one I've seen. I've used them and they work great. They are a bit pricy for the home shop though. I got one from HF that I've used a few times. It's not as nice as a Branick but it works reasonably well and is very safe if used correctly. Sometimes you have to play with it a little to get the springs to fit right. I hate the little threaded rod type with the hooks on the end.
Here's a link to the one I bought. I got it when it was on sale for $79.00.
http://www.harborfreight.com/cpi/cta...emnumber=47890
