Seeking Engine Advice for a 1992 Toyota Pickup
By -
Toyota Pickup
Toyota owner looking to pep up his truck, but he can’t find a 22R locally, so he’s looking for other options.
The 22R-E engine did a masterful job of motivating a group of popular Toyota vehicles, but like all powerplants, as these powerful four-cylinder mills age, they lose power. That led YotaTech forum member “Daniel Fox” to post in the 86-95 Trucks & 4Runners section, seeking advice on improving the power and drivability of his 1992 Toyota pickup. He didn’t include any pictures of his own truck, so we found a couple cool shots of trucks from that era in the forum to add some color to this post.
After searching for an exact 22R-E similar to the one already in his truck and coming up empty in the local area, he began looking for other vehicles that had the same engine. He didn’t completely trust Wikipedia, so he turned to the forum for more insight, leading to some excellent advice and a possible change of plans.
The Introduction
When the OP first shared his question with the forum, he explained what he was dealing with in regard to the troubles with his 1992 Toyota pickup, along with his ensuring problems with finding a replacement engine in his area.
Hi everyone, my Pickup has the 22R-E motor and its really tired, low compression, burning oil, the works, so we’ve been looking for a second motor that we can rebuild so that I don’t have to go without a truck for however long it takes to rebuild it. I’ve been doing research and I’ve only found 1 22R-E and it’s almost 2 hours away. So I broadened my search. Correct me if I’m wrong but I think the 20R and the 22R will both also fit in my truck. I found a list of the cars that had those motors on Wikipedia. Yeah, I know. Wikipedia isn’t exactly reliable. That’s why I’m posting here. Can y’all tell me if this list is accurate and what other motors besides the 22R-E will fit?
Thanks in advance.
The Community Responds
The first person to reply was “old87yota”, who asked for a little more information while providing details on the engine family in general.
Can I assume that you want to keep your truck fuel injected and are just looking for a suitable engine to rebuild?
The list above is right-ish, but there is more to the story. There were a few different versions of the 22R and not all are directly interchangeable with each other.
The easiest and most straight forward thing to do is to find a 22R or 22R-E engine from 1985-1995. The 22R and 22R-E from this time period is essentially the same engine, head and block wise. The difference being carbureted or fuel injected. Your intake and exhaust will bolt right up without fitment issues.
The earlier version of the 22R and the 20R are both carbureted and are a little different. They may physically fit in your truck, but you would either have to adapt fuel injection to these engines or get rid of you fuel injection system and run a carburetor as they use a slightly different head design which also means different intake and exhaust manifolds, which can be done, but not as straight forward as just using a later 22R or 22R-E and would not be my recommendation.
To which the OP replied with this:
I would prefer to keep things as easy as possible but I’m having trouble finding a motor between those years, be it a 22R or a 22R-E. So I don’t really have a problem with going carburated instead of fuel injected or other modifications if necessary.
My biggest complaint with my 22R-E has always been a lack of power. So one of the biggest incentives for putting a new motor in her is to give me more power. If it turns out I can gain quite a bit of power by going with a different model motor entirely, say a 6 cylinder or a 20R with 22R heads just to make an example, and it’s not to much work, I’m willing to do it. Basically, if I’m already gonna have to do some work because I can’t find an easy swap I might as well put in more work to give me some extra power. Any recommendations on what to do or what not to do are appreciated.
Toyota Pickup
While “millball” posted in support of the earlier information.
The only easy thing is to replace with another ’85 to ’95 22r/22re as old87yota said above.
Sure, just about any swap is possible, but you stated that time was of the essence.
Any swap to a different type engine is gonna take time and will have a few unforeseen delays and expenses.
Depending on where you live, there may be emissions compliance issues.
How About a V6?
After that information, the OP began to consider an entirely different direction, buying a newer truck with a V6 and swapping-in the larger engine.
Thank you everyone for the advice. I totally agree it would be much easier to just rebuild a 22R or 22R-E with a few upgrades to give me a little more torque and stick it in the hole. However, I’ve been looking some more and maybe I’ve missed a place that I should have looked but, with the exception of that one that’s two hours away, I just can’t find any.
However, I have found several whole 90s model 4Runners. I’m fairly certain that they all have 6 cylinders but I don’t know exactly what engine it is.
Obviously if I went with a V6 I’d need new heads, exhaust and intake manifolds, an exhaust system, motor mounts, etc. That’s a given. However, because these are all whole cars, I’d already have everything.
The only thing that really concerns me that I can think of is wiring. I’m a good mechanic but I’m just not good with electrical and I doubt any of it will be plug and play.
Can y’all tell me any problems I’m gonna have that I haven’t thought of. For example, maybe the motor mount bolts don’t line up with the existing holes in the frame or something like that. Also, what difficulties will I run into as far as wiring goes?
Also, I live in Louisiana so emissions are not a problem at all for me.
Really appreciate all the advice so far.
Toyota Pickup
But that isn’t going to be easy, as was pointed out by “arlindsay1992”:
Quite literally everything is different with the V6. Motor mounts, bell housing bolt pattern, transmission, and wiring are all different. The V6 engines of that era don’t have a very good reputation either. They are hardly any more powerful than the 22RE, and don’t get very good gas mileage.
That is where the discussion sits today, so if you have insight on this project, or if you live in the OP’s area and have a line on a 22R-E engine, click here to head into the thread to share your knowledge.
Join the YotaTech forums now!
"Before I was old enough to walk, my dad was taking me to various types of racing events, from local drag racing to the Daytona 500," says Patrick Rall, a lifetime automotive expert, diehard Dodge fan, and respected auto journalist for over 10 years. "He owned a repair shop and had a variety of performance cars when I was young, but by the time I was 16, he was ready to build me my first drag car – a 1983 Dodge Mirada that ran low 12s. I spent 10 years traveling around the country, racing with my dad by my side. While we live in different areas of the country, my dad still drag races at 80 years old in the car that he built when I was 16 while I race other vehicles, including my 2017 Dodge Challenger SRT Hellcat and my 1972 Dodge Demon 340.
"Although I went to college for accounting, my time in my dad’s shop growing up allowed me the knowledge to spend time working as a mechanic before getting my accounting degree, at which point I worked in the office of a dealership group. While I was working in the accounting world, I continued racing and taking pictures of cars at the track. Over time, I began showing off those pictures online and that led to my writing.
"Ten years ago, I left the accounting world to become a full-time automotive writer and I am living proof that if you love what you do, you will never “work” a day in your life," adds Rall, who has clocked in time as an auto mechanic, longtime drag racer and now automotive journalist who contributes to nearly a dozen popular auto websites dedicated to fellow enthusiasts.
"I love covering the automotive industry and everything involved with the job. I was fortunate to turn my love of the automotive world into a hobby that led to an exciting career, with my past of working as a mechanic and as an accountant in the automotive world provides me with a unique perspective of the industry.
"My experience drag racing for more than 20 years coupled with a newfound interest in road racing over the past decade allows me to push performance cars to their limit, while my role as a horse stable manager gives me vast experience towing and hauling with all of the newest trucks on the market today.
"Being based on Detroit," says Rall, "I never miss the North American International Auto Show, the Woodward Dream Cruise and Roadkill Nights, along with spending plenty of time raising hell on Detroit's Woodward Avenue with the best muscle car crowd in the world.
