Extra Stout: LS-Swapped Toyota Stout is Ready to Light ‘Em Up
In keeping with the rat rod theme, the cab is a less by-the-numbers setup. There’s the requisite Mexican blanket over the bench seat, along with a wood steering wheel, and some aftermarket gauges. From what we can tell, it looks like this truck was originally a stick, but got converted to auto during the swap. We’ve guessing the clutch pedal now acts as the brake.
The relatively modern head unit looks a little out of place under the row of bullets on the dash, but if it gets the job done, that’s all that matters. Being heard over the engine and squealing tires is probably no easy feat!
You must be logged in to post a comment.
