Fuse Panel under the hood
Old 11-16-2005, 04:45 PM
2000t4r's Avatar
How to you remove it? I need to replace the little white power wire that runs from the battery to the fuse panel. I did a search but didn't find anything.
Thank you
Old 11-16-2005, 04:52 PM
Bob_98SR5's Avatar
look carefully and youll see a clip that you can unclip and remove the cover. this is not rocket science
bob
Old 11-16-2005, 05:51 PM
2000t4r's Avatar
Not the cover the fuse panel itself
Old 11-16-2005, 06:29 PM
Bob_98SR5's Avatar
take a pic and post it
Old 11-16-2005, 06:36 PM
2000t4r's Avatar
How do you remove this? Not the entire panel just the inner section where the fuses are.
Old 11-16-2005, 10:16 PM
L33T35T 4Runner's Avatar
im still confused
Old 11-16-2005, 10:20 PM
Bob_98SR5's Avatar
do you have photoshop or some drawing program where you can draw a line or mark the "fuse panel" that you are trying to pull off?
bob
Old 11-16-2005, 10:21 PM
crappled's Avatar
you have to remove the entire thing, then put a screwdriver in the bottom and 'pop' that section out. that'll give you access to each fuses wiring.
Old 11-16-2005, 11:07 PM
Noliwan's Avatar
Why do you need to pull the whole fuse box out if you're just replacing the white wire...??
From your picutre I know what you are talking about... the white cable or wire is not present , it connects to the lower left corner stud and runs through the top left hole then to the battery-- I have two power wires connected at this point and did'nt have to remove the box at all...
Can you be more specific on what you are trying to do...???
Old 11-16-2005, 11:11 PM
crappled's Avatar
he is trying to remove that area with the minifuses, that requires removing that whole thing so you can access the bottom.
Old 11-17-2005, 09:39 AM
2000t4r's Avatar
I'm trying to remove the panel where all of the fuses are. I can see that there are 3 tabs that need to be uncliped, which I did. The front part of the panel comes out a little way, the back (closest to the fender) doesn't move at all. I'm trying to remove this so that I can replace the white wire. Right now I have sodered with another piece of wire and it looks like crap.
Does anyone have a FSM that they can look at and maybe post a pic on how to remove it, I'm sure that is pretty detailed.
Old 11-17-2005, 11:17 AM
crappled's Avatar
pulling the relays will help, there are 2 more clips in there iirc.
that wont let it pull ALL the way out though, but might be enough for you
Old 11-17-2005, 11:30 AM
2000t4r's Avatar
Thank you for your help? Have you pulled yours out before? Do I need to pull all the relays out?
Old 11-19-2005, 08:41 AM
2000t4r's Avatar
Weekend bump so that I can try and remove it this weekend
Old 11-19-2005, 10:28 AM
crappled's Avatar
i removed it in about 2 min, i just pulled everything out. it's really easy.
i don't remember which clips were by which relay... so no help there.
Old 11-19-2005, 10:46 AM
keisur's Avatar
Originally Posted by Noliwan
Why do you need to pull the whole fuse box out if you're just replacing the white wire...????
You can't replace the white wire without pulling the whole thing. hacve you looked at yours to see the white wire and how it is routed? Might want to and you'll see.
Old 11-21-2005, 07:52 PM
2000t4r's Avatar
I figured it out thank you to Crappled the realy that you need to remove is the large black one closet to the fender.
jasonty
41
12-23-2018 01:00 PM
viesail
08-24-2015 12:21 AM
91yotapup
08-17-2015 09:40 AM
4x4-runner
08-03-2015 07:14 PM
rushw
07-18-2015 01:46 PM
Quick Reply: Fuse Panel under the hood
