Windows Media Player 9 help needed - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-20-2004, 02:24 PM   #1 (permalink)
BT17R's Avatar
I mistakenly posted this in the other Off Topic forum, which should give you an idea about why I'm having computer troubles:
Suddenly Media Player won't run any streaming video at all. From troubleshooting tips on the web, including the MS site, it appears I have a corrupted .wmv codec, maybe other stuff going on too. The steps I've tried, including a system restore, had no effect.
I've done all the virus scans (Housecall and NAV), Adaware, Spybot, re-associated file types, sfc, system restore, and I've forgotten what else. Today I tried additional "fixes" posted on the web, and Corey's idea to reinstall DivX and MS codecs but none worked. I can't find any way to R&R MP9. I'm almost at the point of calling Bangalore, but have received far better advice from techies here. Any ideas? TIA.
__________________
'07 FJ Cruiser TRD SE 6M/T
BT17R is offline
Old 07-21-2004, 05:32 AM   #2 (permalink)
WT
WT's Avatar
Have you thought about do a inplace XP repair ? but I'm not sure if you have a homebuild PC with XP or not but it usually cures alot of wierd IE and XP stuff since it takes everything back to orginal files (you will have to re-patch everything), you may even want to do a CHKDSK /f to see if it will fix and move any files that maybe on bad sectors of the HD.
Oh are you getting any type of error message ?
Also have you simply tried re-installing Media Player from the Microsoft site and let it over right any files with problems.
http://www.microsoft.com/windows/win...es/player.aspx
__________________
96 4Runner SR5 SC | 3" Revtek Front/OME 891 Rear,Diff/Panhard Drop|AirLift bags|285/75/R16 Nitto Terra Grappler|Eaqle 121 w/TRD Logo|Bilsteins|Cross-Drilled PS w/PF Pads|Silver Reverse Gauges|Custom Grill|Catch-All Floor Mats|Sylvania SilverStar|Weather Tech Visors|Clear Corner/Fronts|Alpine MP3/WMA/CD|99+Headlight/Console Mod|K&N FIPK W/Drycharger|Optima Redtop|Trans-Cooler|Remote Start|PICS|PICS2|
WT is offline
Old 07-21-2004, 09:23 AM   #3 (permalink)
BT17R's Avatar
Thanks WT. It's a newer Dell box. CHKDSK didn't do anything, no error messages either. I'll try re-installing MP next. How would I go about an in-place XP Pro repair? I'll let you know how the MP overwrite goes.
__________________
BT17R is offline
Old 07-21-2004, 09:55 AM   #4 (permalink)
BT17R's Avatar
The MP re-install didn't help.
__________________
BT17R is offline
Old 07-21-2004, 10:19 AM   #5 (permalink)
WT
WT's Avatar
Guess a in place repair maybe different with a Dell since I am not sure how they ship there media, is it just retore CD's or do they actually provide a XP full install CD. You will need the full install CD to perform the repair function, but be for warned its possible to really hose things up too, I say back up anything important first just in case, I have done this several times with nothing lost at all but there is always a first.
http://support.microsoft.com/default...b;en-us;315341
Other option is if Dell supplied a set of retore CD it will get you back to the day you got the PC and maybe a option depending on how annoyed you are with the problem. THIS WILL LOSS ALL DATA just a warning too
Just ideas .. so are you not getting any error messages when you try to stream something and is it just audio(radio) or video too ??
Good Luck .....
__________________
WT is offline
Old 07-21-2004, 11:00 AM   #6 (permalink)
BT17R's Avatar
Dell supplied a full set of software to return it to Day 1. No error messages, I get audio fine, no video at all. This happened just as I was about to install my new DVD burner, so I'd like to get it straightened out before installing Nero that I'm thinking could need WMP for playback.
__________________
BT17R is offline
Old 07-21-2004, 11:11 AM   #7 (permalink)
I am not a computer guy at all but I had the same problem! I had to I had to delete the program (from the start- contol panel) then go this web site http://www.microsoft.com/downloads/s...displaylang=en and look up your info for there.
It will wipe out all your vid's that you have!!!!!
Give it a try?!?!?!
NX Tacoma is offline
Old 07-21-2004, 11:16 AM   #8 (permalink)
BT17R's Avatar
Thanks NX, but WMP 9 isn't even listed in the Add/Remove part of Control Panel. From what I've read on different sites, it isn't possible to delete it, but is doable for earlier versions.
__________________
BT17R is offline
Old 07-21-2004, 11:21 AM   #9 (permalink)
Ok try under All Programs, then you will see Windows Media Player....right click to delete. If you want after that you could go to here http://v4.windowsupdate.microsoft.com/en/default.asp and update you PC!
Old 07-21-2004, 11:54 AM   #10 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
Please don't do this - it won't uninstall the player, only delete the shortcut to the app.
Try this...
  • Go to Control Panel
  • Pick "Add or Remove Programs"
  • In the left frame, pick "Add or Remove Windows Components"
  • Scroll down the list, and UNCHECK "Windows Media Player"
  • Click NEXT
  • WMP should be Gone
  • Reboot the system
  • Head Here and re-install Media Player 9
  • That SHOULD help.
I doubt that you corrupted the codec, it sounds like something got installed that took the responsibility of video playback.
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 07-21-2004, 01:12 PM   #11 (permalink)
BT17R's Avatar
Thanks, Mark. I did what you listed, first running Chkdsk and Defrag before re-install. No change in the symptom. I didn't install anything I'm aware of prior to the hiccup. Hmm...
__________________
BT17R is offline
Old 07-21-2004, 02:24 PM   #12 (permalink)
Sponsoring Member
midiwall's Avatar
Dang... this is "fun"...
Can you pass along a link to a video that you can't view?
__________________
~ Mark
midiwall is offline
Old 07-21-2004, 02:44 PM   #13 (permalink)
BT17R's Avatar
I know what you mean. This is the first problem I've had with this computer since new about a year ago.
Here's a typical clip from MS WMP movie trailers.
Direct from MS site
Clicking on "Watch the trailer" gets audio only.
__________________
BT17R is offline
Old 07-21-2004, 03:16 PM   #14 (permalink)
Sponsoring Member
midiwall's Avatar
Okay, so it's just a 1-pass CBR video at 35Kbps done with the Media 9 codec. That should even play on my phone!
Can I ask you to try a couple of other things? Do any of these work? (they're all "safe for work", it's just misc stuff that I have on my server that use different codecs):
http://www.midiwall.com/misc/GasPump.avi
(video, no audio. OLD codec)
http://www.midiwall.com/misc/TysonSkating.wmv
(16Kbps, 1-pass CBR Media 7 codec)
http://www.midiwall.com/misc/HSNKnives.mpeg
(MPEG codec)
(fingers crossed...)
__________________
~ Mark
midiwall is offline
Old 07-21-2004, 03:35 PM   #15 (permalink)
BT17R's Avatar
No video on any links, audio only on 2(.wmv) & 3(.mpeg).
__________________
BT17R is offline
Old 07-21-2004, 06:55 PM   #16 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
You know what might be another problem, some vids require you to use codecs from this site.
http://www.divx.com/divx/
If you get the codecs, go for the free ones, but not the "add supported" 0nes.
http://www.divx.com/divx/download/
Also do not install their player.
You won't need it since you have MS Media Player 9.
Also have you kept up on updating your vid drivers?
Vid drivers get updated quite often.
ATI who makes my vid card releases new drivers about once a month it seems.
Since you have a Dell, when you go to the Windows update site and brose to the new drivers, it should give you Dell video drivers since MS will reconize you have a Dell.
Corey is offline
Old 07-21-2004, 07:42 PM   #17 (permalink)
BT17R's Avatar
Corey, yeah I d/l'd all the DivX codecs. No change. I visit Windows Update daily for Critical Updates and look at driver updates. Nothing there for Dell or on the Dell download site. I uninstalled Quicktime tonight, but no change there either. Still searching, thanks for the suggestions.
__________________
BT17R is offline
Old 07-22-2004, 10:37 AM   #18 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
Yeup... that was part of the test media I asked him to run. None of those clips used DivX, and the MS trailing "most certainly" doesn't.
WOAH! Shame on me for not asking leading questions like "do you have Quicktime installed". Quicktime can have "fun" with the codecs, but I can't explain how it suddenly started happening... Something must have changed, but there's no telling just what it may have been.
With Quicktime now uninstalled, reboot, uninstall media player, reboot again, and install media player.
Let's see if that shakes things up... If it doesn't seem to help, then try this download:
http://www.microsoft.com/windows/win...es/codecs.aspx
That'll pull JUST the latest codecs and force them in.
I've asking folks around work as well, (I work VERY closely to the product that you're having trouble with ) and we're all kinda' voting against Quicktime right now. (biases aside )
__________________
~ Mark
midiwall is offline
Old 07-22-2004, 12:49 PM   #19 (permalink)
BT17R's Avatar
Mark, I did everything you listed in order, plus ran chkdsk and defrag before WMP 9 reinstall, and also uninstalled Firefox. I tested with the MS link I gave...no change, no video, just audio.
I'll try anything else you suggest (short of re-format!). I need to get this straightened out before installing my new DVD burner.
I'll be out this afternoon getting a house ready to sell, and all day Friday through Sunday running an open house (in 100° heat). I'll check back evenings for more tips and tricks. Thanks again!
__________________
BT17R is offline
Old 07-22-2004, 01:00 PM   #20 (permalink)
Sponsoring Member
midiwall's Avatar
WOW... This SUCKS!
Ummm, okay... lemme kick this out to a broader audience here and I'll see what I can shake loose.
(Good luck with the house!)
__________________
~ Mark
midiwall is offline
Old 07-22-2004, 04:52 PM   #21 (permalink)
BT17R's Avatar
Fixed! I remembered the symptom started around the time I rigged my old blown CRT monitor to the secondary video card output. I bought a DVI/Analog converter plug off eBay to make the connection. The monitor still didn't work, but I never removed the secondary plug. I just pulled it, and it works now.
At least I think that's what happened unless it was a coincidence because I also uninstalled IrfanView at the same time. I had checked IrfanView to be sure it hadn't made itself the default video player (or it's plugin).
Thanks for the troubleshooting help everyone, and sorry to get you and your staff needlessly excited, Mark.
So, should I avoid Quicktime? If so, why? Also, when I added the extra codec package, does the computer automatically send those already installed to Recycle? Should I delete the DivX codecs, or are they harmless, or necessary? TIA...
__________________
BT17R is offline
Old 07-22-2004, 05:02 PM   #22 (permalink)
Sponsoring Member
midiwall's Avatar
OH MAN! HAHAHHAHAH!!! The plug must have fooled the garphics card into thinking that it was hot, and XP was routing video over there. NICE!
"Staff" wise... nah, not my staff, I'm just a member of the team.
The nasty thoughts of Quicktime came about because there are issues where Quicktime can be REALLY vigilant about wanting to be the default video player for a lot of media types - including those that WMP has handled since the dawn of time. They CAN co-exist together, but you have to be careful about what you let Quicktime have during install. by default, it grabs most of the stuff that WMP is better at (MPG, WMV, AVI are the top of that list).
DivX wise, nah, leave 'em there. You'll probably trip over something at some point that will need 'em so you already have 'em.
__________________
~ Mark
midiwall is offline
Old 07-24-2004, 01:58 AM   #23 (permalink)
redfox435cat's Avatar
start button -->programs-->windows update
I don't care how "new" your system is. go here the first day u get it. My MP stopped working about 2 months ago. reinstalled it and put in the patches and it was fine.
__________________
04 TRD 4x4 v6
Your Driving? Were we going?
redfox435cat is offline
Old 07-24-2004, 07:12 AM   #24 (permalink)
Staff
Corey's Avatar
Glad you figured it out.
Yep, that DVI plug comes in very handy to do this.
Dual 19" monitors.
I have QuickTIme installed, and when you install it, just make sure it only is setup to play .mov extensions.
Let Windows MP handle all the rest.
QT is very agressive as Mark said.
Corey is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Windows Media Player won't load! Jimmeh Computer Talk 1 03-13-2007 09:23 PM
Windows Media Player help UKMyers Off Topic Talk 4 12-24-2004 05:14 PM
Windows Media Player 10 Churnd Computer Talk 5 10-06-2004 08:29 PM
Windows Media Player ain't workin' Tacoma Dude Off Topic Talk 1 04-09-2004 06:01 PM
Windows XP media player help Tacoma Dude Off Topic Talk 7 07-19-2003 04:36 PM
2009 InternetBrands, Inc.
