| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
replacement video card fan?
__________________
89 Deluxe Short Bed, 3.0 V6 5spd, 4x4, 31x10.5 BFG Radial Long Trails on 15x8 Pacer rims, K&N air filter, high flow cat, Dynomax 2.5" Super Turbo muffler, Sunpro tach... Fiamm 125db. low note horn Pioneer 50w x 4 cd player, Polk speakers |
#2 (permalink) | |
I had the same card did the same thing. its a cheap arse fan with plasic bearings and it went out. My big problem was getting the plasic fasteners off. ATI wont sell another fan and no one make a direct replacement. I shimmied on a thermaltake. 30mm fan? and soldered the old connector on and got it to work. ended up getting a radeon 9200 128 without a fan. IMO it has just as good graphics without the noise and its cheaper. put in a card fan just below the card it the whole system runs cooler
Quote:
__________________
04 TRD 4x4 v6 Your Driving? Were we going? |
#3 (permalink) |
Those fans can be cleaned and lubed (I do it on all my fans when they begin to make noise and a good cleaning can make it last another year before it needs it again) but you need to pull the whole thing apart to do it. Most of them are just held together by a little plastic spring washer which you pry off (make sure not to damage it because you will need it on reassembly). Then I just use 3in1 oil on the bearings and any parts that may have friction.....you would be surprised how dirty they get inside so it is no wonder they just stop spinning after a while. Cleaning it is cheap but if you want an easy fix then just keep looking for a replacement.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#4 (permalink) |
that really sucks that there's not a direct fit replacement. I think I'm going to try taking it apart and cleaning it. I only have an electrical cleaner spray and silicone spray.. never heard of a 3 in 1 oil, where could I find something like that?
thanks for the input, gotta keep the comp runnin so I can make my daily visits to yotatech
__________________
#5 (permalink) |
Im not 100% sure about this fan,
But I know this applies to most Power supply fans, Bay Fans and some CPU fans, If you take the fan off and flip it around there is usally a round sticker on the backside. Pull that sticker off and under in is a hole to put oil in. Sometimes there is a rubber seal you have to pull off... 3 in 1 oil works well or sewing machine oil or gun oil For some reason the manufacturer doesn't seem to install enough oil when they build these things. Whenever I build a PC I always lube the fans up.. This won't work on the Cheaper brushless fans.... Other than that you can get a PCI Slot fan and mount it under the Video Card. Or Fab up fan to fit. |
#6 (permalink) |
Fan card This could would work but the problem is the fan is part of the heat sink so you can blow all the air you want over it but yur not getting enough heat away from the video processor your trying to cool. now if you put in some sort of heat sink on the procesor then a fan card it would work awsome
with this card I would acually try one of these no fan needed. 3 of my freinds use and they work awsome http://www.endpcnoise.com/cgi-bin/e/zm80c-hp.html [/quote]
__________________
04 TRD 4x4 v6 Your Driving? Were we going? Last edited by redfox435cat; 08-13-2004 at 05:12 PM. |
#7 (permalink) |
just buy any ol' small fan off tigerdirect.com (i know not the cheapest but very reliable and the fans are like 5-10 bucks)...just get a fan that uses the pc power and you wont even need to solder......or even better get a new video card....
__________________
06 Subaru WRX |
| Tags |
| 9000, agp, card, fan, fans, graphic, graphics, heat, noise, pro, radeon, radial, replace, replacement, replacing, sinks, video, videocard |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| which video card? | SolidDigital | Computer Talk | 17 | 12-25-2005 08:38 PM |
| Which video card to get? | Churnd | Computer Talk | 9 | 10-17-2005 06:15 AM |
| New Video Card | PutzRunner | Computer Talk | 6 | 02-04-2005 04:08 PM |
| Video Card | Churnd | Off Topic Talk | 34 | 01-26-2004 05:18 PM |
| Video card fan | Corey | Off Topic Talk | 16 | 12-13-2003 12:04 PM |
