| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#26 (permalink) | |||||
__________________
06 Subaru WRX |
#27 (permalink) | |
Co-Founder/Administrator
Staff
More TV out...
This one explains how to enable the ops in your video properties to get TV out to your TV set from the PC, ran across it last night Googling TV out info.
http://www.weethet.nl/english/video_pc2tv_ati.php The one above is for ATI vid card users, but there is NVIDIA info there as well. I learned something on that site last night. I can get the desktop no problemo from the PC to the TV, but have never been able to get a vid to show up on the TV with Media Player, it only showed the player. You have to click on a circle icon to make the TV the primary screen, then vids will show up. Quote:
__________________
Corey 2007 FJ Cruiser Built for 4wheelin', expedition, camping, and overlanding use PNW FJ Cruisers ☺ Detailing 101 ☺ Join Topsites ☺ Muffler Comparisons ☺ Maggiolinas In The Wild FJ Cruiser Buildup ☺ New Roof Top Tent ☺ Video Of My Penthouse Part II ☺ Rehinge Your ARB/Engel Fridge Blog About Roof Top Tents ☺ FJC Magazines Online Review Of My Tent ☺ 2009 Specialized Rockhopper Pro |
#28 (permalink) |
Quick little tweak for windows XP/2003, definetely speeds up menu browsing and the windows desktop in general.
1. Right-click on 'My Computer', click on 'Properties'. 2. Click on the 'Advanced' tab, then under performance click on 'Settings' 3. Click on 'adjust for best performance', then scroll to the bottom of the list and re-click the last 2. This will make everything run smoother, and keep the same windows XP look, i.e. the backdrops for the desktop icons (behind the text, so its not a box like in 98), and the fancy toolbar at the bottom.
__________________
1991 4Runner SR5 3.0L 4wd 5Spd, 31x10.5 ATs, HG replaced 02/05, 320,000km 2008 Acura CSX 2.0L 5Spd, Leather, Sunroof, Wing, Fog Lights, VSA, TC, 10,000km |
#29 (permalink) |
Main programs I use for spyware removal are Adaware SE Personal, Spybot 1.3, HiJackThis 1.98, and CoolWebShredder 2.0.
BUT, I only run these programs once I've removed as much spyware as possible, manually... 1. Go to Start>Control Panel>Add/Remove Programs, and go through and remove whatever you don't recognize installing, usually programs around 0.02MB aren't much more then spyware, use your best judgement. 2. Go to Start>Run, type in 'regedit'. Now, navigate to... HKEY_LOCAL_MACHINE>SOFTWARE>Microsoft>Windows>Curr ent Version>Run In here, delete any entries that look like random characters, or that you don't need running at startup. ** If you have an antivirus, make sure to take a close look at the entries before deleting them, ensuring you're antivirus stays in tact. Do the same in the following folders... HKEY_LOCAL_MACHINE>SOFTWARE>Microsoft>Windows>Curr ent Version>RunOnce HKEY_LOCAL_MACHINE>SOFTWARE>Microsoft>Windows>Curr ent Version>RunOnceEx HKEY_LOCAL_MACHINE>SOFTWARE>Microsoft>Windows>Curr ent Version>RunServices HKEY_LOCAL_MACHINE>SOFTWARE>Microsoft>Windows>Curr ent Version>RunServicesEX 3. The only windows this step doesn't apply to is Win95. Go to Start>Run, type in 'msconfig' (On some windows 98 and ME machines, you might have to manually open the file, 'C:\Windows\System32\msconfig' least, i think its there.. been a while since i used either.. if all else fails, use windows search/find to locate it.)In here, click on the 'Startup' tab, and de-select any and all things that you don't recognize, or don't need, again... being careful not to disturb your antivirus settings. (You may notice some of the things you already deleted in registry, the reason for this is in the registry those were the machines settings, where as in msconfig, its the users settings) Click OK, and you will be prompted to reboot. 4. Now that you have reduced the amount of startup items on your computer and killed as much spyware as possible by yourself, time to start running the programs, really in no particular order, usually i go: a. adaware se(get latest update (released weekly), then full system scan), b. spybot (get latest updates, then immunize and scan), c. coolwebshredder and finally... d. hijackthis, in this program you have to be just as careful as in the registry and the startup config, if you remove the wrong items you can make alot of things on your computer stop working. Go through slowly and remove things based upon your best judgment, and things that you know you don't want. Items beginning with R0 and R1 can be removed, they are just homepage settings, by removing all of those, your homepage will be set to 'default:blank', you can then re set it as you please. If you managed through all that, congratulations, your computer is now, about 95-98% free of spyware... and more then likely running quite a bit faster. Repeat the above steps about once a month, or sooner, depending on how many warez sites you visit. ** All programs mentioned above can be obtained here. ** !!EDIT!! Ooops, forgot to add, you have to do steps 3 and 4 in ALL user profiles for WindowsXP, I know... it's a huge pain, but worth it in the end, promise!
__________________
1991 4Runner SR5 3.0L 4wd 5Spd, 31x10.5 ATs, HG replaced 02/05, 320,000km 2008 Acura CSX 2.0L 5Spd, Leather, Sunroof, Wing, Fog Lights, VSA, TC, 10,000km Last edited by green91runner; 02-15-2005 at 10:08 PM. |
#30 (permalink) |
One more tip that comes to mind at this late hour will benefit laptop users the most, but really it's just an all around great tool that everyone should have, it being.. Daemon Tools.
Downloaded here. This nifty little program lets you mount virtual optical drives, from ISO's, Cue's and a couple outher image files that I can't think of at this moment. You can have up to 4 drives, the benefits of this are.. saving on the amount of burnt discs, or with laptops, if you haven't found a no-cd crack for a game yet, you just mount the image and your computer thinks the cd is in there.. because the motor in the cd-drive isn't being used, you will get a ton of extra battery life.
__________________
#31 (permalink) | |
Quote:
I would also like to recommend using Housecall. This is a free online virus scan, which you can use in combination with your existing one, twice the security, same price ![]() As for the 2 firewalls mentioned, I've used both, Sygate wasn't too bad, but ZoneAlarm drove me mad, constantly popping up and asking 'is this ok'... and since i have a laptop, moving from network to network also brought up more annoyances with it learning the new network architecture, although this is what you want in a firewall, it's something I would rather live without. Also, both programs take a fair amount of system resources, especially on older machines.. ZoneAlarm much more so then Sygate. If you have a router, you have a firewall (99.9% of the time).. which means you don't need to clog up your system with either of these 2 annoying products, and if you don't already have a router I suggest getting one. I mean for $20-30 (less then the cost of some firewall software), you get a firewall and (if your using dsl) a constant connection to the internet, so you don't have to dial-up all the time. Makes it easier to setup a little LAN game at your house too.
__________________
#32 (permalink) | |
Quote:
Doctor.... I appreciate you posting your Windows 98 optimization tips. I never thought I'd find such good computer advice on a Toyota forum! I am moderately computer savy (we'll see if you disagree after reading my question), but I am having a bit of trouble with the virtual memory step. I am supposed to specify a value that is 1.5X greater than the size of my hard drive, correct? My hard drive shows a capacity of 57.2GB with 20.7 available. 57200 X 2 = 85800. Would this be my minimum value? My maximum value was preset at 21273. Does it make sense for the max to be less than the min? When I adjust my settings this way and then go back to check on them, the Minimum shows "0" again. Hmmm...
__________________
1998 4runner LTD 4X4. Anthracite. 110,000 miles and counting... (9/1/2007) |
#33 (permalink) | |
Quote:
256mb RAM = 384mb Min. Virtual, 512mb RAM = 768mb Min. Virtual, etc.
__________________
#34 (permalink) | |
Quote:
I haven't used Windows 98 in quite a while, but if I remember right you can find out how much RAM (memory) your computer has by opening an MS-DOS prompt and entering "mem" at the command line (without the quotes of course). EDIT: Uh, yeah, what green91runner said...
__________________
Kevin 2004 Infiniti G35 Coupe 1998 Toyota 4Runner Limited - Sold Deckplate Mod, Rear E-Locker, Anytime Locker Mod, Commando FM-870, 2 1/2" Lift, 285/75R16 Bridgestone Dueler Revos Kenwood XXV-01D, Sirius Sportster Replay, Memphis 16-ST500D, Rockford Fosgate 4.6x, Image Dynamics IDQ-12, CDT EF-61i Last edited by jimrockford; 03-08-2005 at 10:43 PM. |
#35 (permalink) |
That makes more sense. I have 256mb, so I set mine to 384. Thanks a bunch guys!
__________________
#36 (permalink) |
when using internet explorer OR firefox..
instead of typing in the address bar: "www.yahoo.com" just type in the main part of the address (i.e. "yahoo") and hit CTRL+ENTER it will fill in the "www." and the ".com" at the end. pretty nice feature, and saves some time. -Russell
__________________
2000 V6 TRD 5spd | 1.5" body lift; 2.5" sus lift: SAWs, 8leaf deavers, downey shackles, bilstein 5125s, 32" BFG AT's | Magnaflow 18" muffler, Hella 500s, bentup sliders, polar bear guards, aluminum diamondplate skidplate, clear corners & bumper lenses, tonneau cover | deckplate mod, disable DRL mod, greywire mod, extended diff breather, clutch pedal mod |
#37 (permalink) |
Staff
More power to ya...
Wanna free up some horsepower for better gaming?
Hit Ctrl Alt Delete to bring up your Task Manager. Before a game I always right click the various icons down by the system clock and turn them off such as my anti virus app and others. However there is a lot of extra stuff running that you do not need to have that can free up as many as 10 or more running processes and free up 100 MB or more of extra RAM for you. When you get into the Task Manager, hit the Processes tab. Then click on Username to sort them. Choose your name and shut down them all except for explorer.exe and taskmgr.exe. You need the former for Windows shell, and the latter is the app you are in doing this. When I do mine I go from around 32 processes down to 22, and free up about 100 MB of memory. You should find that your game will now run better than before. This tip I just read today in the Battlefield 2 manual on improving performance. BF2 is a memory hog.
__________________
#38 (permalink) |
Staff
7 tips to a cleaner PC
Saw this on CNets site.
http://reviews.cnet.com/4520-10163_7....html?tag=bnav Lots of vids there too. Keeping your PC clean, especially inside the case is important to the life of it.
__________________
#39 (permalink) |
This site will help you out.
Best computer info in here period. [H]ard ocp http://www.hardforum.com/
__________________
~Todd 2001 4Runner V6 SR5 4x4 , Sway-A-Way Racerunners , Old Man Emu rear shocks & coils |
#40 (permalink) |
Free up some memory by going to Start - Run - type "regedit", then:
1. Find the key [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentV ersionExplorer]. 2. Create a new DWORD sub-key named ‘AlwaysUnloadDLL’ and set the default value to equal ‘1′ to disable Windows caching the DLL in memory. 3. Restart Windows for the change to take effect. As always, make a backup of your registry if you've never tried editing it before.
__________________
-Chris If you can't explain it simply, you don't understand it well enough. Click here to search! My Website |
#41 (permalink) |
Senior Member
__________________
98 Limited 4x4, Rockstomper skid, Rockware Front bumper, Warn HS9500i, 1" RB BL, Tundra coils front & OME HD rear, Nuke quick discos, diff drop'd, 305/70/16 Baja Claws, Electric Locker, couple of battle scars, but nothing major :) |
#42 (permalink) |
Senior Member
__________________
#43 (permalink) |
Staff
Got dead pixels on your LCD?
__________________
#44 (permalink) |
Windows Explorer shourtcut tip
When using windows explorer to manage your files, would you prefer that is automaticly displayed the contents of a specfic drive right away rather then having to click on it. If so, all you have to do is modify an existing shourtcut.
The standard "target" in the shortcut should look like this "%windir%\explorer.exe" Change it to this "%windir%\explorer.exe /e, C:\" to have it automaticly display the contents of the C:\ drive or change C to whatever drive letter you want to it show automaticly. I will say that it's best not to choose the drive letter of a CD/DVD device as if you don't have anything in those drives at the time, it can cause a long hang/pause which can ultimately cause the explorer shell to crash.
__________________
Trying to be different, Just like everyone else. 94' Pickup DX 2wd A multitude of VW's 97' Vmax |
#45 (permalink) |
Relocate your "My Documents" folder.
Why? To prevent loss in event of a system crash or hard drive failure. Right click "My Documents", then "Properties". Under Target folder location, click "Move", and select the new location. Click OK, then watch it work. From now on, your documents will be stored there, but will work like usual. Just remember where they are so you don't accidentally delete it! For most machines, a secondary internal hard drive is the ideal place to relocate your documents. If you do this, create a directory on the secondary drive and point the new target to that. I wouldn't recommend an external drive, because those can be turned on and off too easily. Another possibility is to partition your main drive... one for the OS and programs, and one for your documents. Problem with that is if you run out of space, you're stuck unless you have a partitioning tool like Partition Magic. Lots of possibilities with this, but the idea is simple... to preserve your files. Also, this is not a substitute for regular backups... it just adds to your peace of mind.
__________________
#46 (permalink) | |
Quote:
CCleaner...trust me your PC will thank you. get it at www.ccleaner.com
__________________
'95 PU Ext. cab, 4wd OEM 3.0L with spark delivered by OEM Ignition 348,xxx miles, on sixth set of tires sittin' on OEM wheels '04 Silver Corolla S, DVD head unit going in soon '85 F-250 351W H.O. 401,000 miles, first 351W dead at 367,xxx miles, Hedman headers, flowmaster exhaust, $1200 audio system, Alpine Alarm |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Building a new PC | Churnd | Computer Talk | 17 | 10-14-2005 06:22 AM |
| PC memory | Corey | Off Topic Talk | 9 | 01-21-2004 10:47 AM |
| PC Tips | Corey | Off Topic Talk | 3 | 09-13-2003 11:13 PM |
| It's time for a new PC | Corey | Off Topic Talk | 19 | 08-23-2003 05:16 PM |
