Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
How much memory can XP Pro handle?
I've read no more than 3 Gb, but that was some time ago, before SP2. I'd like to go with 4 Gb, notebook memory is so cheap right now.
Also, what brand do you recommend for notebooks? New Egg has the best deals on Kingston and Crucial going now. For all I know it's all the same, just relabeled, but see there's a difference in latency and a couple of other things that may matter. Here's a link to the type my laptop uses. TIA... http://www.newegg.com/Product/Produc...d&Order=RATING
__________________
'07 FJ TRD SE 6M/T 100% Black '09 4R SR5 TE 5A/T Shadow Mica--Inbound |
| Sponsored Links |
#2 (permalink) |
you can run a auto check here http://www.memorygiant.com/ should tell you how much you can use
#3 (permalink) |
Windows will read up to 4gb memory post SP2. However, not all applications will actually take full advantage of all that memory.
As far as brands, IMO as long as you stay away from the no-name stuff your probably OK. Pretty much all the major brands are good, just get one with the specs you want.
__________________
-Ben '87 4Runner, Turbo'd 22RE, CT26 @ 15psi, Worked Head/Cam/Valves, FMIC, 450cc injectors, MegaSquirt, SS IFS Truss, Manual Hub swap, 4.88 gears, Rear ARB, Front TruTrack, OME Shocks/Leafs, 1.5" BJ Spacers, 33" TrXus on black ProComp wheels. |
#4 (permalink) |
Xp Pro sp2 Will handle upt to 4gb, if you want more you will need to step up to XP Pro X64 I have up to 64gb on this before.
#5 (permalink) |
You can put 4GB in but windows will only recognize 3gb. You might as well get the full 4 gb in case you ever decide to go to a 64 bit operatiing system, and like you said its really cheap right now.
__________________
1994 4runner SR5 3.0L |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Memory to cloths | Stinkbone | General Electrical & Lighting Related Topics | 0 | 03-01-2006 01:33 PM |
| all pro HD coils and pro comp es9000 question... | dewey | Offroad Tech | 3 | 10-25-2005 10:16 PM |
| PC memory | Corey | Off Topic Talk | 9 | 01-21-2004 10:47 AM |
| pro comp susp. lift on 2nd Gen. PRO vs. CON | tdv | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 12-06-2003 08:32 PM |
| Memory Settings | nixmax | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 04-15-2003 06:04 PM |
