What do I need to run a wire to the battery? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > GPS & Communication
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-27-2006, 09:29 PM   #1 (permalink)
SC4Runner's Avatar
I bought a CB and I want to run the pos wire to the battery. I know the wire isint long enough.
Should I buy some 12 gauge wire, crimps to link the two and then what do I need to attach it to the battery wire bolt thing.
Im such an electronic noob I read all the tech articles, but they dont state the obvious!!
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe.
1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe.
SC4Runner is online now
Old 03-27-2006, 09:53 PM   #2 (permalink)
sc,
i really recommend putting in an auxiliary fuse box and then power up your cb and all your future 12v accessories from it. did you see my writeup in the tech section (the cobra 75 one).
never crimp wires, imho. what an unstable connection. give it a good yanky yanky, and there goes that connection. always solder. look in the tech section for my "soldering 101" writeup
connecting to battery: use a ring connector. they are found at the auto parts store.
grounds: make sure you take some paint off and then use a self-tapping metal screw to secure it.
that should give you all the info you need. any more questions, write me back but *after* reading the writeups referneced above. ill know if you didn't
bob
Bob_98SR5 is offline
Old 03-28-2006, 06:21 AM   #3 (permalink)
shawn0890ss's Avatar
Send a message via AIM to shawn0890ss
well said but i still have to admit that i crimp a lot of my wires just because it is easier, i just might have to redo my stuff no that i have the means to do so and need to run new lights anyway.
shawn0890ss is offline
Old 03-28-2006, 01:19 PM   #4 (permalink)
there are times that crimping might be acceptable. for instance, t-tap'g a connection that runs perpendicular from a wire that is buried or bundled very close to other wires. but for SC's wiring job, he needs to connect and extend the cb's wire from the battery to the cb. butt connecting this would work, but not be the best, most permanent way.
Tags
battery, cb, run, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
how to run power wire from battery to amp? NinjaWa Vehicle Audio & Home Entertainment 7 07-06-2007 04:27 PM
1986 4Runner: Wire from battery to fuse box (FL)? iGGz General Electrical & Lighting Related Topics 4 08-04-2006 11:05 AM
Where/How did you run the Amp Wire? wsudu Vehicle Audio & Home Entertainment 9 05-05-2005 09:44 PM
where does the 3rd brake light wire run? TBob 95.5-2004 Tacomas & 96-2002 4Runners 1 12-08-2004 12:58 PM
Where to run cb antenna wire when mounted on r/rack? skshepherd 95.5-2004 Tacomas & 96-2002 4Runners 8 03-29-2004 08:22 AM
2009 InternetBrands, Inc.
