Subwoofer Enclosure Building question:
Im putting a system in my 2000 4Runner. Im planning on using 2 Kicker Solo-Baric S12L7D4s powered by a KX1200.1.
Kicker says for sealed enclosires, each chamber should be between 0.8 cu. ft. and 2.0 cu. ft. I designed an enclosure that has roughly 13.5x13.5x12.75" chambers (approx 1.3Cu. Ft.).
The thing is, I think the specs Kicker gives is for speakers mounted with the baskets inside hte box. I want to mount my subs witht he baskets sticking out. Do I need to change the size of the chamber to accomodate this?
Just becuase: Ill be using .75" MDF, Double thickness Baffle, stepped in end panels (so carpet looks good), internal perimiter brace 6" from back. This thing is going to be rock solid.
CPD4runner
9
11-05-2017 06:01 AM
1965chevy
09-20-2015 07:33 PM
