subs fit in a tundra?
My 4runner's tranny is all messed up and i am just planning on getting a new used tundra about 2001-2004. I had 2 15" kicker solo baric L7s in the 4runner and i still want to be able to use them, do you guys know if there's any way they would fit? If i can't put two you think i'd be able to put at least 1? I was wondering if there was a chance i can put them under the back seats? thnx
are you going to get a tournea(sp?) do that and port them inside the cab. if not you might have to cut out the bottoms of the back seats and put them under there or put them in the center rear seat
man.. 15".. thats insane.. i have a 12" sitting right behind the drivers seat with the rear seat folded up. amp is underdrivers seat! Wish i can have a custom mount right under the rear seats.. but i think 12" is way too big for it. Goodluck!!!! ~keep us posted
there are special boxes they make that is actually a seat and your woffer goes in it and people could just sit in it or i believe you can cut out holes in your floor to mount your woofer but i would not recomended cause it is way too hard to do and there might be problems with it. You can also make a custon fit box to fit your woofer in the back.
Also 15' is too big I am running a 12' with a alpine v-power amp it almost bumps as hard as my friends 15'. If you get a 12' with a right kind of amp it will sound good too.
Remember woofer boxes make a diffrence too when listening to woofers but so does the brand of woofers.
choppe777
05-16-2016 08:00 AM
