| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Dual Batteries Installation
#2 (permalink) |
What parts do I need? I have the wiring, terminals, battery terminals already. Im getting the Optimas either today or tomorrow. What else would I need?
#3 (permalink) |
__________________
'02 4Runner - '06 XRunner Breakdancing www.BadgeYourRide.com Check this out Multi-Touch Interaction Research http://mrl.nyu.edu/~jhan/ftirtouch/ Highest Xmax 6.5" subwoofer made Total Posts: 32,218 (75.35 posts per day) [/center] [/color] Still A Neon |
#4 (permalink) | |
Quote:
Would this be accomplished with a different isolator, or is that just int he wiring? |
#5 (permalink) |
Super Moderator-Sponsoring Member
Staff
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#6 (permalink) |
Wait, you have the isolator there, but in this pic I see your batteries are directly connected to each other?
#7 (permalink) |
Staff
I have REAR dual batteries....w/ the third in the stock location.
You want dual batteries...the Painless kit is the way to go...I just modified it and got a dual battery cable kit and linked the rear dual batteries in parallel and then put them into the "dual" kit w/ the front battery. Does that make sense? Nothing to it. Everything is on my link.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale Last edited by waskillywabbit; 05-25-2005 at 07:01 PM. |
#8 (permalink) |
2 yellow tops will work, but it would probably be a better idea to get a red top for starting and a yellow for the aux.....
#9 (permalink) | |
Staff
Quote:
__________________
#10 (permalink) |
he isnt going t orun 3 batteries liek you did... hes running 2... the yellows are made for being discharced and recharged a lot..... the starting batteries are not... they both have differnt purposes meant for differnt things and you should match the battery capability to what it isgoing to be doing.....
#11 (permalink) | |
Staff
Quote:
__________________
#12 (permalink) | |
Quote:
actually while i was typing that, i was actually thinking to go with 2 red tops.... the redtops can handle the drain, you arent using it in a marine or long storage situation, bith will get used, and both still capable of starting routinely..... also the reserve capacity on the red tops is not much less than the reserve capacity on the yellows... and who actually draws full output amperage for as long as it takes to drain a battery without recharging or starting it? |
#13 (permalink) |
sorry to hi-jack, but im thinking about getting a yellow top, and using it for my car, and then using my current battery (dunno what kind, all i know is its only 525 cca) for my stereo, would that work??
__________________
///kyle ==================== 95 4RUNNER 6 1/2" blaupunkt components 6X9 Polk/MOMO diamond audio D5 300.4 4 elemental designs 9kv.2 subs kicker kx400.1 PIAA 9004 driving lights 31x10.5x15 bridgestone dueler a/t's |
#14 (permalink) |
you could do that, but why? a lot of people jsut want he yellow top for a stereo and have no idea why otehr than its a cool mod that i can do...... are you planning on really running a dedicated isolator setup so both batteries will charge? or what?
a yellowtop will start a vehcile, but it will not start a vehcile better than a redtop would..... granted a yellow top will outperform a red top in a deep cycled environment with stuff that actually uses deep cycling..... |
#15 (permalink) |
Staff
Drained my one dual last weekend listening to the radio in my truck all weekend long, just to drain the battery. I had to switch the system over to charging the rear duals from the alternator as the radio was clicking on and off and under 10Vs to get it going again.
Next time I go wheeling will be primitive and you can bet your I'll use all the power I have.
__________________
#16 (permalink) |
The question is NOT red/yellow/blue/orange top...the question is can your alt keep up with your accessories?
If you alternator is overloaded in EVEN THE TINYEST AMOUNT, go get a deep cycle and NOT a red top. Even slightly deep cycling a Red will kill it in short order and I speak from experience on that one. Currently I am running 2 ULTRA deep cycles (equivalent to the Blue Top) they perform flawlessly and I have left my dome light on for a straight 48hrs and they still had plenty of umph to turn over the engine....I then let the 190amp alt do it's thing! If you have an alt like mine and no accessories, and want starting power when the temp is -40F or more, get the Red. The Red was specifically designed to start in extreme temperatures were other batteries fail.
__________________
3vze, 4x4, sr5, 90, auto, LSD 2x dB Drag World Finalist 2003 Nopi Nat. Street B champ 2004 SBN Street C champ 2004 SBN Advncd NW Champ 2004 Former WR Holder in NW. SPL: 159.8db @ 42hz In loving memory of Jamie Riggs 5/15/85 - 10/8/04 Last edited by Bumpin' Yota; 05-27-2005 at 07:45 PM. |
#17 (permalink) |
ps - dont drop a huge sum of money on an isolator system....
Go buy a larger starter solenoid. A starter solenoid is basically a HUGE relay capable of passing LARGE amounts of current. Wire it up so that the batteries are kept electrically separate when the ignition is off, and so that they are paralleled when the ignition is turned to ACC.
__________________
3vze, 4x4, sr5, 90, auto, LSD 2x dB Drag World Finalist 2003 Nopi Nat. Street B champ 2004 SBN Street C champ 2004 SBN Advncd NW Champ 2004 Former WR Holder in NW. SPL: 159.8db @ 42hz In loving memory of Jamie Riggs 5/15/85 - 10/8/04 |
#18 (permalink) | |
Quote:
#19 (permalink) | |
Staff
Quote:
If you don't know how to do it on your own, get a kit, it was EASY to install...less than an hour...and it does all that...have you read my website link as to the 3 modes of operation????? ![]()
__________________
#20 (permalink) | |
Quote:
#21 (permalink) | |
Quote:
on that pix, just connect the ACC wire to the IGN ON CIRCUIT... plain and simple... so apparently, you wish to listen to stereo when the engine aint running?
__________________
leo d. stock 90 4runner |
#22 (permalink) | |
Quote:
so how come a red top is paralled with a yellow? in theory, not just the same kind of battery. but try to get the same battery off the same pallet. if not the same production line! any diff in the batteries will have a bad effect on both. one will be lower and try to suck the juice off the other. then visa versa. that's why i think that HELROARING product is the best, since it ISOLATES the main batt to the aux, which charging them simultaneously. heck, if you have space, install dual alternators...
__________________
#23 (permalink) | |
Staff
Quote:
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale Last edited by waskillywabbit; 05-31-2005 at 07:51 PM. |
#24 (permalink) | |
Quote:
#25 (permalink) |
the hellroaring one has a circuitry built into it so this stuff is not really needed or used.
i had a long conversation with one of their sales rep a fewwwwwwww years ago, and i kinda dont remember the intricate workings of the HR unit.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| dual batteries w/out isolator | dfoxengr | Offroad Tech | 5 | 02-26-2007 09:47 AM |
| Dual batteries under the hood | BajaTaco | General Vehicle Related Topics (Non Year Related) | 85 | 03-01-2006 05:23 AM |
| dual batteries | rugerm44 | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 11-10-2003 04:58 AM |
| Dual Batteries | Churnd | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-02-2003 05:01 AM |
| dual batteries? | doink | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 02-09-2003 09:58 AM |
