Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Accessing front speakers 2nd 4runner
Old Apr 10, 2005 | 11:56 AM
Ontario's Avatar
Before I have a go at it - I need to replace the front speaker (driver side). Do I need to dismantle a lot of the front dash inorder to access the front speaker? - Or can I just remove the LOWER FINISH PANEL no. 1 (below the steering wheel) on it's own?
I just needed to ask before I start - I have a tendency to break more things than repair them...
Thanks
Old Apr 10, 2005 | 12:21 PM
Brendan's Avatar
simple stuff.
all you have to do is remove all the screws labeled E. there are 5 on the left and 5 on the right (3 on the top, 2 on the bottom - both sides). on the right side, the upper screws are accessed from the inside of the glove box. for the top 3, you'll need a phillips screwdriver. for the bottom, you need a 10mm socket. pop of the the plastic piece around the ignition (no tools needed) and then remove the dash pieces to get at the speakers. voila.
Old Apr 10, 2005 | 02:03 PM
leebee's Avatar
watch for a small clip on the drivers side, you may have to slide the panel towards the drivers seat to disengage the clip. im presuming it is the same as the passenger side. just go slow and look close as you start to remove it. you should need to remove only the 5 screws, 'e' on the drivers side to get at the dead speaker.
lee
Old Apr 10, 2005 | 02:12 PM
Ontario's Avatar
Excellent...
leebee & Sizzlechest - thanks guys. I appreciate the help.
Old Apr 10, 2005 | 07:42 PM
ROMAD's Avatar
Check out the PDF from the site below:
http://www.installdr.com/InstallDocs...a/4Runner.html
Old Apr 10, 2005 | 08:27 PM
Fahrenheit 451's Avatar
Since you mentioned a propensity towards breaking things: the hood and gas door lever are over there and the fittings on the ends of the cables like to break really easily if stressed in the wrong direction so take it easy with them.
I don't remember all the details offhand, but I think you can remove each before removing the cover itself and that helps a lot in not getting them in a bad position.
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
