Sign in using an external account
| The Fab Shop Tube buggies, armor protection and anything else that requires cutting, welding, or custom fab work |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
#2 (permalink) |
Vendor
Sales Rating: (10)
I wouldn't recommend it...even if it IS possible. I don't know WHY you would do it. Just get some sheet metal...and if you've never welded before...don't start w/ sheet metal.
#3 (permalink) | |
Personal
Sales Rating: (0)
Quote:
__________________
2000 Taco SR5 V6 5speed TRD Airaid MIT Vortex muffler DEI 2-way Extang Tuff Tonno III |
#4 (permalink) |
Personal
Sales Rating: (0)
No you can't weld aluminum to sheet metal. I'm a welder/maintenance techincian. Do what TACOMANATOR advises and you should be OK. Or you can opt out for some good old pop rivets to make the patch, although I don't recommend it for the long haul. Good luck.
__________________
1999 Toyota 4Runner SR5 w/TRD supercharger, e-locker, K+N FIPK kit, and a bunch of other stuff the government won't let me talk about. |
#5 (permalink) |
Personal
Sales Rating: (0)
hehe there is a way to bond steel and aluminum together, we had this process done often on our NASCAR southwest tour car. That way when the item was checked with a magnet it passed......
There is no way to weld aluminum to steel with conventional welders, the process used an explosive source to force the steel to impregnate into the aluminum...... |
#6 (permalink) |
Personal
Sales Rating: (0)
No, with most normal welding equipment you cannot attach dissimilar materials. For example, steel to steel and aluminum to aluminum. Welding steel with MIG can be accomplished fairly easily with some practice, whereas TIG welding aluminum can be a trifle more challenging.
__________________
84 4Runner SR5 22R, 5spd, 31" BFG ATs,custom bumpers 08 FJ Cruiser Sandstorm, 6MT, All-Terrain Package, Rock Rails, BFG A/Ts |
#7 (permalink) |
Personal
Sales Rating: (0)
I agree with Tacomanator and the others. I had to replace the areas around my rear wheel wells. I cut out the bad areas and tacked in replacement sheet metal with MIG, placing the welds about and 1" apart and moving around on the piece to let it cool and not buckle. The gaps were then filled with bondo. You can get a mix of bondo and glass. That seems to hold better.
__________________
'90 4Runner SR5 22RE 5spd 4x4, Pacesetter header & downpipe, Magnaflow 18" oval, 2.25" pipes, Rock Crawler 51 15x8 Steel Wheels, Pro Comp 33x12.5 ATs, Aisin Hub Swap, 2" BL, Energy Suspension Mounts/Bushings, K&N Filter, Accel Coil, NGK Iridium Plugs & Blue Wires, Toyota Brush Guard, Allpro Offroad Rear Bumper w/ 2" receiver, SB SureSteps, Whiteface Glow Gauges, Husky Liners, New Front Fenders, Radiator |
#8 (permalink) |
Personal
Sales Rating: (0)
I know for a fact that it cannot be welded together, trust me I had to do it when I first started work. To bad it was a joke and I didn't know any better. At least I knew maintnace doesn't have a aluminum magnet.
__________________
When I was younger I hated going to weddings. It seemed that all of my aunts and the grandmotherly types used to come up to me, poking me in the ribs and cackling, telling me, "You're next." They stopped that crap after I started doing the same thing to them at funerals. |
| Tags |
| aluminum, metal, sheet, weld |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Aluminum Radiator? | dannyh | 86-95 Trucks & 4Runners | 9 | 12-23-2005 09:23 PM |
| aluminum radiators | rollandfayssoux | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 03-05-2004 05:38 PM |
| Need info about aluminum | Plays_with_Toys | Off Topic Talk | 4 | 10-21-2003 06:27 AM |
| Aluminum Pedals | Cebby | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 04-15-2003 10:24 AM |
| Steel or Aluminum??? | joshik | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 03-06-2003 12:47 PM |
