Single Cab Bumper Build
Old 08-27-2012, 07:12 PM
  #41
Teuf's Avatar
Originally Posted by TylerH
Its a lincon 220v. Dont know the model and im using 80/20 argon i believe.
DCEP? hard wire?
Old 08-27-2012, 07:20 PM
  #42
TylerH's Avatar
Its wired correct. Everything is good now. The Shackle hangers were welded and they came out great.
I was wrong about the mix, its just CO2.
Old 08-27-2012, 07:56 PM
  #43
Teuf's Avatar
OK C02 can be a little messy. Got it.
Old 08-30-2012, 11:24 AM
  #44
racerflea's Avatar
that looks great!! if ur gonna powder it iwould go ahead and add the holes and notches for the winch but if ur just rattle caning or home painting i would leave it as is till u get the winch
Old 08-30-2012, 08:37 PM
  #45
TylerH's Avatar
Thanks. Thats what i plan on doing. I want to powder coat but thats $100 dollars or so i dont want to put into this thing. Im just going to resand it with 220, primer once more, add texture paint and then add about 3 coats of rustoleam*.
Old 09-05-2012, 09:48 PM
  #46
TylerH's Avatar
Took a long trip with the bumper on and i noticed the truck was running un-normally hot. So i think i need to put holes in the front so the the radiator can breath better. Any suggestions?
Old 09-06-2012, 07:40 AM
  #47
racerflea's Avatar
Maybe u could cut diwn the front section to where it would cover less of the radiator
Old 09-16-2012, 09:43 PM
  #48
nedhills's Avatar
I love that bumper. I'm going to do something very similar to my yota but with a bit of a tube bumper on top. nice job.
Old 09-16-2012, 09:49 PM
  #49
TylerH's Avatar
Im still thinking about a small hoop. Dont know yet.
I cut the holes for the fairlead* today. Going to finish with some cuts and the next day i have off, hopefully have this thing back on by october.
I want to start a new project lol.
Old 09-16-2012, 10:38 PM
  #50
racerflea's Avatar
Then move to the rear!!! Lol
Old 10-09-2012, 02:55 PM
  #51
TylerH's Avatar
Final Product. All lights work.
Old 10-09-2012, 03:41 PM
  #52
rhysdavis's Avatar
looks clean ashell man nice job!
Old 10-10-2012, 06:00 AM
  #53
nedhills's Avatar
nice job! looks sweet, do you have the winch in yet?
Old 10-10-2012, 11:40 AM
  #54
TylerH's Avatar
No not yet. I have some other projects lined up before i purchase a winch.
Althou winter is around the corner.
Old 10-21-2012, 04:43 PM
  #55
thefishguy77's Avatar
Looks great was the winch cable cut out enough to help with running hot or do you still have to cut a few more openings? Regardless it looks fantastic.
Old 10-21-2012, 05:14 PM
  #56
TylerH's Avatar
I dont know to be honest. I have not drove it long enough distances to get it hot, And its been like 45 degrees here. So that helps keep it cool. I sure hope it keeps its cool enough. I also cut out two tenis ball size holes under the shackle mounts. In theory the air should hit the bottom corners of the radiator.
Old 11-14-2012, 05:21 PM
  #57
vikkz's Avatar
thats a really nice bumper you made.
What size steel did you use, 1/4" 3/8" or did you use the thicker stuff for the reinforcements and thinner stuff for the shell of the bumper.
Just asking that because that is going to be my next project soon after i get done with the york compressor on a 3rz with AC.
Old 11-17-2012, 05:53 PM
  #58
TylerH's Avatar
Its 99% 3/16 steel which i kinda regret. Everything is gusseted and braced very well. The only 1/4 steel is the bottom mounting brackets. The reason i used it there is cause i had to take the bumper off every night and most the time that was the only thing holding it up. This thing weighs around 100 lbs so i didnt want that steel to bend.
If i could do it over i would of used more 1/4 on the main structural points. And also on the winch plate. I dont know how that is going to hold up being 3/16.
Old 11-17-2012, 07:08 PM
  #59
michael1963's Avatar
Excellent looking bumper you have there sir....lots of work put into that and it shows.
Old 11-17-2012, 07:13 PM
  #60
Bucholz24's Avatar
thats a good lookin bumper! Nice job
Quick Reply: Single Cab Bumper Build
