removable doors
removable doors
I am wanting to hinge the doors on my 85 short bed so that they can be easily/quickly removed. Does anyone know of a kit that is available for this or is this something I will need to fab myself?
https://www.4xinnovations.com/mobile...-Kit_p_59.html
cutting the hinge pin as described above does work but some times the brass bushing gets screwed up when you try to drive the pin out. Not a big deal if you have a couple of sets of hinges.
this set adam at 4xinnovations makes it a quality product
Also, brash bushings have long fallen out, but its a tail only truck so they doors dont get alot of use.
https://www.yotatech.com/forums/f116...-doors-245153/
This is what I did after hacking up a couple of sets of hinges.
Disregard the white Hinge on the left..that brain cramp failed miserably. .I notched the Top bolt hole, allows you to loosen the top bolt slightly and the door will rest in the notch. I can swap both doors in about 10 minutes and it is very secure.
tighten and adjust and I am good to go.
theking11863
03-19-2016 09:36 PM
britishdudes2dr
07-25-2015 06:47 AM
