YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-10-2006, 07:24 PM   #1 (permalink)
Ranski's Avatar
Ranski's 85 4Runner Buildup
Quote:
edit: you guys are mising the point. Its a labor of love to build these things up. You dont do it b/c its practical. You do it b/c its what you like.
by sdastg1
That couldn't be more true. I have never done anything like this and figured what better way to learn than to take on a rig that will pretty much need attention top to bottom.
Quote:
Have fun and keep posting pics as you progress. I for one don't get sick of the build-up threads...that is about all I really look for these days. All the rest are bling!
by Wabbit
Wabbit this thread is for you
Here we go...
The story starts with an 85 4Runner that nobody wanted. Seems like a bad flashback from high school...she was ugly I was desperate...
Here is the pic of the rig when it was posted here.
At the time I owned a 2000 4Runner w/ all the popular mods, including Sonoran rear bumper, TC skid, blah, blah, blah...
I have since sold it and purchase a Sequoia to eventually tow the 85 around.
Specs:
85' 4Runner
22RE (Clean and runs)
Auto
185K miles
Rusty
Basic Plans:
Marlin 4" Lift
Marlin Crossover
5.29 Yukons
Aussies front and rear
V6 Calipers up front w/ LC vented rotors
Stock calipers/rotors in rear (more on that later)
33" MTR's until I can find a deal on 35's
Frame plating
Sticker Removal
I brought it home last Sept and have been spending my time since then removing rusty parts and rebuilding the front axle. I should have the front all buttoned up tomorrow night.
Wish me luck...
__________________
Randy
2006 Sequoia
1985 4Runner: Build-up has begun
Build-up Thread: http://www.yotatech.com/showthread.php?t=80743
www.tornadoalleycruisers.com
TLCA #12443
Ranski is offline
Sponsored Links
To remove this ad, register today!
Old 03-10-2006, 07:43 PM   #2 (permalink)
dragr1's Avatar
Wabbit has a brother?
__________________
1985 4Runner Dual e-lockers, dual cases, yada yada
'00 Suburban 2500 4x4
'07 Tacoma Double Cab 4wd TRD
'02 Lexus IS300
1991 Tiffin Allegro 31' Class A
dragr1 is offline
Old 03-10-2006, 07:43 PM   #3 (permalink)
Ranski's Avatar
Pic of axle before cleanup
Pic of axle after cleanup and paint
Pic of v6 calipers after cleanup and paint
__________________
Randy
2006 Sequoia
TLCA #12443
Ranski is offline
Old 03-10-2006, 07:47 PM   #4 (permalink)
1985 4Runner's Avatar
Send a message via Yahoo to 1985 4Runner
Glad to see you starting a buildup thread. I will be doing my 85' 4runner also. Good luck to you & I'll be following your progress.
Ryker
__________________
U.S. Marines: Providing the enemy an opportunity to die for his country since 1775...
Firefighter, EMT-B, US MARINE 92-96
I wasn't born with enough middle fingers.
Quote:
Originally Posted by fustercluck
Indeed I am a Toyota slut.
click here to see my 1985 buildup thread
Myspace
1985 4Runner is offline
Old 03-10-2006, 07:51 PM   #5 (permalink)
shazaam's Avatar
Send a message via MSN to shazaam
cool I got quoted in a build up thread ...
__________________
Experience is a hard teacher because she gives the test first, and the lesson afterwards.
<-- the artist formerly known as sdastg1
shazaam is offline
Old 03-10-2006, 08:01 PM   #6 (permalink)
Ranski's Avatar
Rear Disk Conversion
I was visiting with the guy that set-up my gears (Duane w/ Techtafab) and he showed me his brackets and adapter plate he is making for a rear disk conversion.
Here is the thread on Pirate w/ the details:
http://www.pirate4x4.com/forum/showthread.php?t=432279
__________________
Randy
2006 Sequoia
TLCA #12443
Ranski is offline
Old 03-10-2006, 09:10 PM   #7 (permalink)
getitdone's Avatar
subscribing.
__________________
Chris Fischer
3D 85 4Runner SR5 | 33" BFG M/T on flat black rims | Chevy springs | Custom Grab cage with overhead cb mount | Custom fabbed center console | Freshly rebuilt axle with IFS hub/caliper swap | Rock Sliders | Lots more...
In Colorado, Dig.
getitdone is offline
Old 03-10-2006, 09:19 PM   #8 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Awesome Randy...I'm looking forward to watching...and givin you a hard time.
waskillywabbit is online now
Old 03-12-2006, 08:51 PM   #9 (permalink)
Ranski's Avatar
Front Axle Rebuild
Well as is par for the course the axle rebuild took twice as long as anticipated.
Items that held me up along the way...
Figuring out the technique for getting the axle back into the birf with that pesky inner snap ring.
Modifing snap ring pliers so that I could reinstall the outer snap ring.
I'm not real confident I got the preload right on the wheel bearings, it sure seems like it takes alot of force to rotate. The scale says something like 30lbs.
The FSM's instructions were pretty squirrly so I just followed Roger Browns way of doing it. I'll have a friend over in a few weeks to check it out.
QUESTION:
The stock bolts for the calipers won't fit through the V6 calipers. The hole seems to be a tad too small. Has anyone else run across this. Not sure if I should grind out the holes in the calipers or not. It would seem that if I ordered v6 bolts they would be just a tad too small for the threads on the knuckle housing.
__________________
Randy
2006 Sequoia
TLCA #12443
Ranski is offline
Old 03-14-2006, 12:07 PM   #10 (permalink)
Ranski's Avatar
Well it seems I've answered my own question.
ERROR: I assumed the bolt that was in the caliper was stock...WRONG!
I picked up my new bolts from the dealer and took them home. Three of the bolts fit perfectly the third wouldn't tighten down...hmmm
Well it turns out that the previous owner had stripped out the threads on the knuckle housing - Recut new threads and used a larger bolt. SO...looks like I will be grinding out one hole in my calipers so the old larger bolt will fit.
__________________
Randy
2006 Sequoia
TLCA #12443
Ranski is offline
Old 03-15-2006, 05:48 AM   #11 (permalink)
99_Runner's Avatar
Send a message via MSN to 99_Runner
Good thread, can't wait for more updates. Good luck with the build.
__________________
Drew
99 4Runner SR5, auto, 3.4 V6, factory rear locker, 265/75 Yokohama Geolander AT+II
Stock for now, but hopefully not for long.
99_Runner is offline
Old 03-20-2006, 07:37 PM   #12 (permalink)
Ric
Banned - User requested
Ric's Avatar
any more updates ?
Ric is offline
Old 03-20-2006, 08:04 PM   #13 (permalink)
Ranski's Avatar
Quote:
Originally Posted by Ric
any more updates ?
Well I have been doing battle with the steering box. Most of the mounting bolts are difficult to get to and in my case very rusty, so I have been calling on my best friend PB Blaster to help me out. I am one bolt from being able to remove it. It is the fitting connecting the pressure line to the steering box. It is on there TIGHT! I won't beable to get back to it until Thursday night.
Both shock mounts have been removed - the only thing left to cut off up front is the torque rod bracket.
I'm trying to schedule my buddy to come over and weld up all the necessary front suspension/steering parts the first weekend in april.
Good to hear from you Ric...it has been awhile...a lot has changed in my Toyota world since you left KC.
__________________
Randy
2006 Sequoia
TLCA #12443
Ranski is offline
Old 03-20-2006, 08:27 PM   #14 (permalink)
Ric
Ric's Avatar
yea, i see that, but looks good so far, keep up the great work...
Ric is offline
Old 03-20-2006, 08:35 PM   #15 (permalink)
FilthyRich's Avatar
me like
__________________
Eric
88 4runner
Quote:
Originally Posted by AxleIke
"Just wheel what you got until it doesn't cut it anymore".
FilthyRich is offline
Old 03-21-2006, 04:27 AM   #16 (permalink)
bruzer1123's Avatar
I love watching buildup threads. Keep up the good work!
bruzer1123 is offline
Old 03-30-2006, 07:22 PM   #17 (permalink)
Ranski's Avatar
Update:
Received my last few parts from Marlin today. Looks like all this stuff will be put on the middle of next week.
I spent the past weekend, grinding down all the surfaces AND I finally got that pesky fitting off the power steering box. All it took was a GOOD set of flare end wrenches, 3-foot cheater pipe and 4-days of PB Blaster.
Couple of things I'm tracking down between now and then include:
  1. I purchased the 12" Bilsteins and saw on Tatums build thread he ended up swithcing out to the 14" length...posted on Marlin to see which will work.
  2. I have a question concerning mounting the "regular" shock hoops. The mounting points aren't flush with the frame as the shock bracket comes in contact with the wheel well.
Not flush w/ frame
Shock bracket in contact with wheel well
__________________
Randy
2006 Sequoia
TLCA #12443
Ranski is offline
Old 03-30-2006, 07:28 PM   #18 (permalink)
Sponsoring Member
What I did...
All the other pics on my website under the front axle.
Old 03-30-2006, 07:34 PM   #19 (permalink)
Ranski's Avatar
Quote:
Originally Posted by waskillywabbit
What I did...
What size Bilteins are you running up front 12 or 14?
__________________
Randy
2006 Sequoia
TLCA #12443
Ranski is offline
