rag joint delete help.
Old 10-29-2015, 04:57 PM
mtdave2's Avatar
I need to get rid of the rag joint on my 91 truck, I would like to go to a universal joint style for clearance. I have searched but cant find the exact info im looking for.
I am not sure how many splines and what size my steering gear is, is there a universal fit joint that works? anyone have a part number?
will the pre 82 or so shafts work?
any input is helpful, thanks
Old 10-29-2015, 11:35 PM
wyoming9's Avatar
Red face
Just what are you working with you need to change things ??
Are you going to a solid front axle??
Engine swap??
I think the easy way would be measure and count the splines.
Old 10-30-2015, 08:56 AM
blake.nemitz's Avatar
if it was me i would source another shaft from the salvage yard and cut off the u joint with a couple inches of shaft. cut off rag joint and weld ujoint in place of the rag joint. might be a little ugly buy cheap and easy and if you can weld good strong too
Old 10-30-2015, 07:31 PM
mtdave2's Avatar
I can't be the first guy to do this. Someone surely makes a kit...I hope?
Old 10-31-2015, 02:36 AM
Fossilized
Staff
dropzone's Avatar
you are gonna have to weld
http://www.flamingriver.com/index.php/products/c0005
Old 10-31-2015, 04:25 AM
mtdave2's Avatar
Well if I have to weld , fine, but I guess I don't need anything then. I'll just weld in metal bar to replace rag joint. It is a straight shot anyway
89hilux1
09-14-2015 06:13 PM
elaketiger
09-14-2015 09:58 AM
dguzzi
09-03-2015 08:48 AM
swerks
08-23-2015 06:32 AM
Quick Reply: rag joint delete help.
