extended driveshafts
Old 06-06-2005, 08:59 AM
88yotaboy's Avatar
Im getting an 86 4runner with the allpro 5 in sas, and im going to need a new front driveshaft for it. What are my options for this? Should i just go with marlins extened shaft kit or should i get a custom one made? What are the costs involved with custom shafts?
Thanks,
Andy
Old 06-07-2005, 06:20 PM
After all the problems my buds had w/ Tom Woods I went with High Angle Driveline and couldn't be happier. Shafts are pricey though. If you don't need anything fancy just a longer shaft I would just find a driveline shop to lengthen it
Old 06-08-2005, 09:56 AM
88yotaboy's Avatar
hmm...
Old 06-08-2005, 10:04 AM
Jared Ajlouny's Avatar
square driveshaft, look on pirtate 4x4.com
Old 06-13-2005, 04:56 PM
Albin's Avatar
My version of the front square driveshaft, why I did it and how.
Good luck.
Square Driveshaft Project
Al
Old 06-13-2005, 05:53 PM
waskillywabbit's Avatar
A minimum of an 8" slip spline up front and get a custom driveshaft built. Do it right and figure to spend $250. I had custom front and rear ones built/balanced w/ a CV joint in the rear and 8" slip spline up front and it was $400 parts, $100 labor.
Old 06-13-2005, 09:05 PM
88yotaboy's Avatar
waskilly who did your driveshafts? and do i have to do a custom rear shaft right away?
kawazx636
10-06-2021 03:03 PM
primordialbeast117
12-19-2015 12:23 PM
kcaudill
10-10-2015 02:39 PM
kbpickens
10-02-2015 03:37 PM
Odin
09-26-2015 06:56 PM
Quick Reply: extended driveshafts
