Changing upper control arm bushings...the alternative
#87
Installed the brake lines today. Just need to align it as the steering wheel is cocked to the left, put bumpstops on, and get this driveshaft thing figured out.
It rides pretty good. The springs and shocks work well, it tracks straight, and has no vibration. Sometimes if I hit a bump just right I get some bumpsteer, so I will add a steering stabilizer.
As for the cart I owe my friend, well lets just say I lowered the lift a little too much.
#88
Originally Posted by Marc P
...As for the cart I owe my friend, well lets just say I lowered the lift a little too much.
At least you were in a somewhat private shop when you did that. I had to walk it back to the counter a la "the walk of shame"
#90
Originally Posted by Tanto
Been there done that, although it was an oil collector
#95
I installed the SS brakelines and got my draglink adjusted so my steering wheel is straight. Still need bumpstops and a driveline.....
Also need to figure out how to rewire the 4x4 light so it comes on....Robinhood? 4runnerkid? Josh?...anyone??
#98
you dont need a light marc!!!! so when is the maiden voyage? i want to go wheel but honestly it might have to be a night run because its been so friggin hot
