YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Community > Check Out My Truck > 4Runners-3rd gen
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-27-2006, 06:26 PM   #1 (permalink)
pattycakes77's Avatar
pattycakes77 (patywgn) '98 4runner
Please abide by the admin rules and DO NOT POST IN THIS THREAD. Thanks.
The PattyWagon
Last Updated: 2008-08-28
1998 Toyota 4runner SR5
Desert Dune Pearl paint code 1A5 (00258-001A5-21)
100K miles so far (08-28-08)
3.4L V6 Automatic
4WD
Engine:
3.4L V6 Automatic
Deck Plate Mod
Airbox Elbow Removed
Airaid jr Intake Part # 510-934 (installed 5-09-07)
Amsoil Synthetic Oil used
TrueFlow Air Filter as of 2007
TRD Billet Aluminum Oil Cap (pretty)
TRD Cat Back Exhaust (replaced rusted tip with a stainless "Magnaflow " tip and looks much better)
New Belts May '07
B&M SuperCoolerTransmission Cooler, Part # 70264
Interior:
LED Green lighting conversion
MagLite D Cell on passenger side
'99+ Center Console Upgrade (Thanks Bob!)
'99+ Roof Console
Wheelskins steering wheel cover
Driver's Side upper grab handle
Alpine SPS-170A 6.5" speakers in all four doors
Alpine CDA-9847 CD/MP3/WMA head unit
2nd Gen inclinometer modified to fit in dash DIN under stereo
Autometer Sport Comp Gauges: Transmission Temp, Volts, Oil Pressure
Custom (i know that sounds lame) radio bezel with angled gauge pods, made by ME! Click for more info!
Exterior:
Sport Hood (Installed Dec '07)
'02 Multi-Reflective Headlights
'02 Multi-Reflective Taillights and Corner lights
'02 Chrome Grille (also Satoshized my '98 when i feel like sporting it)
Blacked out bumper signal lights
Turn Signals in Side Marker Lights
Tacoma Skid Plate (dress up) (PT212-35040)
Removed running boards (beefy)
Rear License Plate Surround color matched
SR5 badges on sides (why should Limiteds have all the fun?) (75442-35070)
TRD Off-Road stickers on sides (why should Tacomas have all the fun?)
In Channel Vent Visors
'06 Tacoma 5-Spoke Wheels
Tacoma Wheel Locks (00276-00900)
265/75/16 BF Goodrich All-Terrain T/As
Toyota Bug Deflector
Stainless "4Runner" license plate frames
Undercoated
Powdercoated Tow Package (started to rust)
Cheapo front mud flaps
Misc:
'00 Tundra Brakes (199mm calipers)
Goodridge Stainless Brake Lines front, rear
FIAMM Air Horn with switch to go back to stock horn (people think it's a Farrari)
ABS Disable Switch (for people who like being in control of their vehicle) not quite finished, but working on it
Toyota Neck Pillows (more like middle-vertabrae pillows)
ECT and Rear Window Switch Relocated
Full size matching '06 Tacoma 16" TRD spare
Suspension:
Sonoran Steel 7.1 Lift Kit with Upgraded Tokico shocks up front and 10mm trim packer spacers.
Older Pics:
These are pics of my ride with and without the running boards and also with my stock wheels that i did a fancy paint job on. the paint job didn't last but i'm keeping my stock wheels and having the same paint job done but with powder coat and saving for a set of winter tire/wheel set.
__________________
The PATYWGN: 1998 4Runner Desert Dune Pearl.
PATYWGN show-off thread
PATYWGN on Cardomain
Pattycakes77 on Myspace! let me be your friend... please?
1985 Toyota 4runner 22RE 5-speed SFA - For Sale :(
pattycakes77 is offline
Sponsored Links
To remove this ad, register today!
Old 12-01-2007, 12:01 PM   #2 (permalink)
Inclinometer and Gauge install 2007
i've started a thread HERE to show this off but i've decided to add to my PATYWGN thread with an in depth show and tell on what all i've done.
Supplies:
2nd gen inclinometer
Bondo
gutter guard or some kind of mesh
PVC pipe that fits your gauges of choice
various LEDs that fit your vehicle, i chose 194s and 74s in GREEN
sand paper: 60, 120, 240, and 320 grit
a Dremmel tool with various grinding bits
Gauges of your choice, i chose Autometer Sport Comp
18 gauge wire of various lengths and colors
Interlocking quick disconnects for your wiring from Radio Shack
wire splices, i chose 3M T-Taps from discountcarstereo.com
various wire connectors, male, female and cirlcular
a drill of some sort
flat head and phillips head screw drivers
Bull Dog adhesion promoter
Krylon Fusion "textured shimmer" spray paint
Satin Polyurethane in a spray can
3/8" transmission hose
Dakota Digital Sender Block (optional)
3/8" male hose connects
6-10 small hose clamps
Teflon tape
Transmission cooler (optional), i chose a B&M
Zip ties
Electrical tape
Split loom tubing
a volt meter
lots of time and patience
First i started by installing the transmission cooler. i chose a B&M because "they have a low pressure-drop design, there is less oiling-system restriction" just to be on the safe side. it also came with brackets, nuts, bolts, zip ties, and various fittings for an easy install even though i decided to do a custom install. bending and cutting the brackets to the desired length and shape took some time, and figuring out where to mount it was a little challenging too. i decided to put it on the passenger side as low as i could in front of the radiator to give it as much air as possible, keep as much air going to the radiator as possible, and it was close to the trans lines for connecting. the top brackets were mounted in some unused holes for the radiator supports, the bottom brackets were mounted in holes i drilled and tapped in the same spot the stock front skit plate is mounted. i cut the soft transmission hose that sends the hot fluid to the internal transmission cooler in the radiator. this line was then secured on the male barbed fitting i put on my transmission sender block mounted to the frame on the passenger side. on the exit side of the sender block was another male barbed fitting that i attached some 3/8" transmission hose to and routed between the frame and the tow hook to the mounted B&M transmission cooler. it was a tight fit and to keep it from rubbing a hole in the hose, i put a 1/2" piece of hose around the 3/8" hose that would be in contact with the frame and tow hook and anywhere else i saw a possibility of contact that might rub a hole in the hose. i zip tied the soft hose in place where i could find. i ran another length of 3/8" trans hose back around the front of the vehicle, zip tied it to my tacoma skid plate bracket, between the frame and stock front skid plate, and into the internal transmission cooler inside the radiator. filled fluid back to the correct levels and checked for leaks. transmission cooler install was done. i'll get to the wiring of the sender next.
here are some pictures to help you see what all that text translates into. i have them "tagged" in photobucket but i'm not sure if that will show up here, you just put your cursor on the image and it should bring up some text about what everything is.
The wiring was probably a bit more work that usual because even though it would be covered up, i am a perfectionist and i didn't want to see wires run all over my engine bay. i crimped on ends to fit the sender and ground and ran them back along the frame and then over to the crossmember in the engine bay. then crimped on the proper end to fit on the oil sender (installed in one of the empty plugs next to the stock oil pressure sender for the idiot light) and ran that wire with the other two up along the same wiring for the alternator and battery wiring. once there i ran it behind the fuse panel in the engine bay and attached the ground to an existing batch of ground wires on the fender. then i ran the remaining two sender wires back to the firewall. i drilled a small hole and put in a grommet big enough for the two wires to pass through. once i had the wires at their proper length and where they needed to go, i enclosed them in black split loom tubing and wrapped it all in electrical tape to seal them in from the elements and give it that OEM look. you can't even tell that anything is different, looks like it was there from the factory. ok, now with the lower dash panel off on the inside driver's area, i pulled the wires in further to work with them some more. i crimped on 3 more of the ring terminals to some black 18 gauge wire for the grounds that go to the gauges. with my volt meter, i traced some wires back from the ignition switch and bugged them until i found a 12v switched source to power my guages. tapped into it with my 3M T-Taps and grouped all the wires together and fed them behind the radio bezel where the gauges were going to be. again, i encased them in the black split loom tubing and electrical tap to keep them apart from everything else and keep things clean looking. i went to Radio Shack and bought some male and female 12 position interlocking connectors
stripped the wire ends and attached the terminals and put them in order on 3 of the levels on the male connector: 12v power, sender, ground. wired the female connector in the same way. now i had a quick disconnect for the gauges if i wanted an easy way of disconnecting them later. on the other ends i put some female fully insulated quick disconnect terminals on the ends to attach to the gauges themselves. the wiring for the lights was done in almost the same way. since i wanted to have these dim with the switch with all the other dash lighting, i tapped into the wire for the ash tray light for my power source since i was eliminating the ash tray and had no need for it. used my 3M T-Taps, ran the wires to another set of male and female interlocking connectors, ran the gauge light wires to the interlocking connector and it was done. it's always a good idea to attach your lights and your gauges to your wiring and give it a test before you put everything back together.
that's all for now, i'll detail the inclinometer modification and building the gauge pods into the radio bezel next week and add pics as i go so you get a crystal clear idea of what i did.
2007-12-01
__________________
Old 12-03-2007, 05:07 PM   #3 (permalink)
Sonoran Steel 7.1 System Installed
Sonoran Steel 7.1 System Lift Installed 12-01-2007
This is a picture of the front driver's side with my new Tundra Blue Tokico shock, Tundra spring and 10mm spacer. also note, i've got my Tundra brakes and Goodridge stainless brake lines installed.
Here is the Passenger side.
A picture of the differential drop spacers installed.
A view from the back. You can see the adjustable panhard bar installed, the extended brake line, the Landcruiser shocks, Old Man Emu springs, and the extended bump stops.
Another picture, this is the rear passenger side.
and some fully installed pictures of how she sits.
Thanks to Steve for a smooth and easy purchase and great directions and website to make the install a piece of cake (cept for the iowa rust!). i highly recommend you buy from Steve if you are considering a suspension lift.
Updated pics (2008-03-03) with painted Sport Hood installed and car washed!
had a chance to wash it up without it freezing right away, it warmed up to about 40 degrees on sunday!
wow, is that SUN reflecting off the windows? haven't seen that in months!
a good side shot
and a view from the front as if you were about to be run over!
__________________
Old 02-03-2008, 01:11 PM   #4 (permalink)
Various Part Numbers
Some part numbers that may be helpful to others. I have used these parts on my 4runner in various repairs or additions, and prices when available. Please note that these worked on my 1998 Toyota 4runner SR5 with 3.4L V6 Auto. If you have any questions, please feel free to PM me!
75431-35020 Emblem, Back Door ($28.01)
PT212-35040 Tacoma Skid Plate ($135.00)
11213-62020 Gasket, Cylinder ($21.75)
11193-70010 Gasket, Spark Plug ($4.16)
17176-62040 Gasket, Air Purge ($11.44)
12204-62010 Valve Sub-Assy PCV ($8.90)
75442-35070 Plate, Back Door,chrome SR5 badge ($19.61)
90080-91090-83 Belt, V Alternator ($11.15)
99364021070-83 Belt, V Vane Pump ($10.67)
99364-20870-78 V-Belt ($24.13)
53301-35170 Hood Sub-Assy, Sport Hood ($325.29)
76181-35901 Bulge Hood ($114.15)
76192-35010 Plate, Hood Bulge ($13.20)
76182-35020 Guide, Hood Air ($13.58)
76184-12020 Protector, Hood ($0.71) Don't Buy
76185-35010 Protector, Hood ($7.00) Don't Buy
90263-04054 Rivet ($0.57)
90167-45005 Screw, Pan Tappin ($0.72)
76183-12030 Protector, Hood ($0.71)
90179-06324 Nut ($2.20)
76187-35010 Retainer, Hood ($0.89)
53111-35400 Grille, Radiator, '01/'02 chrome grille ($146.84)
75311-60090 Emblem, Radiator ($22.55)
81560-35200 Lamp Assy RR, '01/'02 Tail Lamp ($127.49)
PT228-35960-HP Hitch Receiver plug 2" ($8.97)
48131-AF100 Spring, Coil, FR
48531-69417 Absorber, Shock, RR
48510-A9160 Absorber Assy, FR
00276-00900 Tacoma Wheel Locks '06 ($40.00)
04945-35040 Shim Kit (for 199mm Tundra Brakes)
04465-0c012 Pad Kit, Disc Brakes 199mm
04479-0c020 Cylinder Kit, caliper rebuild kit (199mm) ($13.22)
90080-24077 Pin w/hole, brakes (199mm) ($1.43)
04479-35040 Cylinder Kit, caliper rebuild kit (stock '98 4runner) ($23.70)
90080-11373 Bolt, w/washer (skid plate, '98 4runner) ($0.77)
53512-35030 Filler, Fr Bumper, Right($23.21)
53513-35030 Filler, Fr Bumper, Left ($23.21)
16100-69398-83 Water Pump ($125.24)
13568-69095 Timing Belt ($49.40)
13540-62021 Tensioner ($39.38)
13503-62040 Idler ($90.37)
13505-62070 Idler ($121.26)
90979-01192 Plug, Spark ($3.13)
19037-62010 Cord Set, Spark Plug ($61.82)
90467-12040 Clip, Front Grille
90210-05007 Washer, Seal Valve Cover
90339-03002 Plug, Throttle Body
90467-07041-E0 Clip, Interior Fastener
00258-001A5-21 Touch Up Paint ($7.18)
23300-62030 Filter Assy, Fuel ($32.87)
75321-60010 Plate, Radiator ($25.52)
00602-12108-004 Billet TRD Oil Cap ($44.14)
00602-17400-011 TRD Cat Back Exhaust ($549.95)
__________________
Old 02-25-2008, 03:22 PM   #5 (permalink)
To Do List:
1. Herculine rockers and lower door jambs
2. Some 6" driving/fog lights up front
3. Re-do my Satoshi grille
4. Dimple my front and rear bumpers, pound dent out of driver's rear bumper end, possibly paint bumpers.
5. Re-seal my headlights
6. Sequential or regular turn signals in trim piece under headlights. (in progress)
7. Possible fog light conversion in turn signal lenses on factory bumper. (in progress)
8. Finish and install 1st Gen roll bar. (almost done!)
9. Hilux Surf hatch and tire carrier swap (maybe soon?)
10. Finish and fix LED interior lighting
11. Skid plates up front
12. Figure out ABS disable switch
13. Recover '02 Limited sun visors and install (homelink and lighted vanity mirrors) (in progress)
14. Clean undercarriage and coat with POR 15
15. New Hitch
to be continued...
__________________
Old 03-14-2008, 02:29 PM   #6 (permalink)
Maintenance Record
2004-03-17: Installed '02 Chrome Grille.
2004-03-12: Installed '02 Multi-Reflective Taillights
2005-02-XX: Installed '99+ Multi-Reflective Headlights and Corner lights
2005-06-15 Installed new OEM frame mounted Fuel Filter.
2006-03-21: Color matched rear license surround and new 4runner emblem.
2006-05-10: New 265/75/16 BF Goodrich All-Terrain T/A KO tires.
2006-06-XX: Installed '99+ Center Console and E-Brake Handle.
2006-06-XX: Installed 99+ Roof Console.
2006-06-09: Removed Factory Running Boards.
2006-10-26: New '06 Tacoma 5-spoke TRD Wheels.
2006-12-02 Oil and Filter change @ ? miles, Amsoil Ea057 filter and Amsoil 5W-30 Synthetic used
2007-05-XX: Installed new drive belts.
2007-05-09: Installed Airaid Jr. Intake Tube (Part # 510-934) and TruFlow Air Filter
2007-05-28 Oil and Filter change @ 91,843 miles, Amsoil Ea057 filter and Amsoil 5W-30 Synthetic used
2007-07-XX: Installed Dual Filament sockets for Turn Signals in Side Markers.
2007-07-XX: Installed OEM Rebuilt Tundra 199mm Brake Calipers, Brembo OEM style Tundra Rotors, Goodridge Braided Stainless Brake Lines front and rear, Bendix Brake Pads, and flushed brake system with Valvoline Synthetic Brake Fluid.
2007-10-XX: Installed SuperCoolerTransmission Cooler (Part # 70264)
2007-11-XX: Installed green LED lighting to dash and gauge cluster.
2007-11-XX: Installed modified stereo bezel with Autometer gauges (Oil Pressure, Trans Temperature, Volts) and DIN modified 2nd Gen inclinometer in dash.
2007-12-01: Installed Sonoran Steel 7.1 System Lift Kit with 10mm rear spacers and Blue Tokico shocks.
2007-12-10: Full size matching spare, '06 Tacoma TRD Wheel.
2007-12-10 Oil and Filter change @ 95,325 miles, Amsoil Ea057 filter and Amsoil 5W-30 Synthetic used
2007-12-28: Installed color matched Scooped Sport Hood.
2008-03-13: Replaced valve cover seals/gaskets, spark plug tube seals, intake plenum gaskets, Denso spark plugs, and new set of Toyota plug wires. I used all Toyota OEM parts and did the labor myself. I also took this opportunity to clean the throttle body and both pieces of the intake plenum as much as I could with various brushes and Carb cleaner inside and out.
2008-08-07 Oil and Filter change @ 99,547 miles, Amsoil Ea057 filter and Amsoil 5W-30 Synthetic used
__________________
Last edited by pattycakes77 : 08-09-2008 at 02:42 PM. Reason: updated service records
Old 08-28-2008, 05:08 PM   #7 (permalink)
I just had a milestone with my 4runner... i'm now in 6 digits on the odometer.
got it at 62K over 5 years ago, so that's only about 7600 miles per year since i bought it, not bad. hope to keep her going strong well into the 2-300K mile range, then rebuild and start over!
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
pattycakes77 toyaholic Seller/Buyer Ratings For Members 5 04-26-2008 06:46 AM
Got a new (to me) 98 4runner 94 sr5 Newbie Tech Section 26 11-15-2006 12:23 AM
98 4Runner 4x4 5sp sr5 $8,100 or trade or built 1st gen 4Runner JM Vehicles - Trailers (Complete) 3 09-23-2006 12:28 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
