Fink's '85 4Runner - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Community > Check Out My Truck (No one can answer you in this section) > 4Runners-1st gen
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-17-2009, 12:28 AM   #1 (permalink)
Staff
4x4Fink's Avatar
Fink's '85 4Runner
1985 4Runner 22RE SFA 4x4
175k original miles
Mechanical
  • Steering knucles (torn apart, replaced worn parts, re-packed)
  • Front brakes (new pads, resurfaced/turned rotors, drilled and re-tapped pins, cleaned/re-installed calipers)
  • Rear brakes (new shoes, cleaned, adjusted, new wheel cylinders)
  • E-Brake (replaced cable, adjusted)
  • WabFab/Trail-Gear Big Bore master cylinder
  • Thermostat (replaced)
  • Water pump (replaced)
Off-Road
  • OME Dakar leaf springs front and rear
  • OME Nitro Charger shocks front and rear
  • OME Steering dampener
  • Low Range Off-Road axle gusset
  • 4.88's with Detroits front and rear
  • 35x12.50 BFG KM2's
  • 15x8 Pro-Comp steelies
  • Diff armor front and rear
  • Sliders
  • Extended brake lines front and rear
Interior
  • Pulled flooring and cleaned floorboards
Exterior
  • Bed-lined exterior
  • Sylvania H6054 Headlamps
Future Mods
  • Undercarriage cleanup
  • Optima Red Top
  • 2nd gen seats
  • Interior cleanup (wash, sand, undercoating)
  • High Steer
  • V6 brake conversion
  • Complete stereo upgrade
Day I bought it
Fink
4x4Fink is offline
Old 09-06-2009, 11:42 PM   #2 (permalink)
Staff
4x4Fink's Avatar
OME leafs and shocks
Trail-Gear front spring hanger
Extended front and rear brake lines
WabFab Optima battery tray
Fink
4x4Fink is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
