Need to Buy no slip locker,Help Diff size.
I need to buy a no slip locker. I dont know what the mesurements are of my diff. How do i tell. I have a 2wd 99 limited 4runner. I have also searched and i cannot find where to buy one. Allways just installation guides
no its a 2wd, what else do i need to know besides the 8'' rear unit. Because when i look to order a locker there is other numbers that i dont know.
1 Post
A good diff shop should be able to look up the proper diff. When I ordered my ARB from Randy's Rings they figured out what I needed. I had heard 4 different locker part numbers from others and the locker that I got is the one ARB specs on their website. Let the shop specify the parts needed.
P.S. What do you mean by "no slip locker"?
its a powertrax no-slip locker. Which is a lunch box and engages itself. Made much the same as a lockrite (made by same company) but has an alloy around 67% stronger than titanium. The clicking sound made when you go around corners is said to be elimated. Said to be around 98% better on road than a lockrite. I have researched it some people say it is a limited slip but IT IS A LOCKER. It is also only around $120 more than a lockrite. Very reliable and reviewed highly. Said to be the best lunchbox you can get. Here are some sites.
http://rockcrawler.com/techreports/p...x_tj/index.htm
http://www.rocky-road.com/noslip.html
http://www.4x4wire.com/reviews/no-slip/installation/
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
