| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Installing Sonoran Steel Shackle Hangers
#2 (permalink) |
if youre speaking about my writeup, which i think is the only writeup on this topic, you have to bend the skid plate because i had to. perhaps your year 4runner has a narrower skid plate or steve made them more narrower.
also, you should prime the metal instead of just painting on it. one thing i forgot to mention (and do) is to clear coat it as well, though mine has held up well and frankly speaking, i dont need this to look shiny and pretty. its a shackle hanger, after all and i beg to differ on your "tighten as tight as possible" advice. seems to me you are compounding your problem with getting off rusted bolts caused by the weather in your neck of the woods. while steve did not post any torque specs, i always like the rule to hand tighten + 1/4 to 1/2 turn. bob |
#3 (permalink) |
just my opinion, but 8.8 bolts may be on the weak side, 8.8 is equivalent to a grade 5, while 10.9 bolts are equivalent to grade 8, i certainly wouldn't want that thing flying off (which it probably wont) again, just my $.02
__________________
- Joe 1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks 1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs |
#4 (permalink) |
grade 5 is pretty strong... i have grade 5 bolts holding half my truck together...
#5 (permalink) |
I was under the impression 8.8=Grade 8. Guess Ill go looking for the 10.9 bolts then. (Took me a while to find these 8.8 bolts)
Bob, I believe it was your writeup I was referencing. I wasnt taking a stab at you. I saw another writeup else where that asked for bending hte skid plate also. I did prime the metal. Couldnt find any of that metal etch stuff, so I just used Rustoleom primer, then Rustoleom Flat Black. I was going to use the Rustoleom primer, then Duplicolor wheel paint and clear coat, but didnt have the time to wait for that paint to fully cure (8-10 days!), and I dont need, nor want it shiney. If this paint ever comes off though, Im going to have it sandblasted, and Ill find that metal etching stuff and use wheel paint. |
#6 (permalink) | |
Quote:
#7 (permalink) |
Super Moderator-Sponsoring Member
Staff
Shackle hangers are made to pull the FULL weight of your vehicle.
USE GRADE 10.9 bolts (Grade 8 equivalent) or anything that is going to see any kind of real loading. If you are holding it together, Grade 5 is fine. Those bolts I imagine would need to be torqued to somewhere around 70 ft-lbs cause you DON'Tt want them coming/wiggling loose by any means.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Sonoran Steel Shackle Hangers | cstamm | The Classifieds GraveYard | 3 | 10-05-2007 02:30 PM |
| Sonoran Steel Shackle Hangers | HaveBlue | The Classifieds GraveYard | 17 | 10-15-2006 05:49 PM |
| Sonoran Steel Shackle Hangers | Bighead | The Classifieds GraveYard | 5 | 08-09-2006 05:10 AM |
| Sonoran Steel Shackle Hangers | cstamm | The Classifieds GraveYard | 3 | 06-28-2006 05:48 PM |
